Community Member
AP 1532i failes to join WLC 2504
I get the following errors when a new 1532i series AP tries to join a 2504 series WLC:
*Nov  7 20:51:28.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.97.65.210:5246
*Nov  7 20:51:29.031: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Nov  7 20:51:29.083: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Nov  7 20:51:29.119: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Nov  7 20:51:30.083: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Nov  7 20:51:30.139: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Nov  7 20:51:31.139: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Nov  7 20:51:38.835: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join timer expired
*Nov  7 20:51:38.835: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join failed expired
*Nov  7 20:51:38.835:  Mesh setting the ethernet port 0 state to 0
*Nov  7 20:51:38.835: %MESH-6-LINK_UPDOWN: Mesh station 78da.6e60.914c link Down
*Nov  7 20:51:39.083: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Nov  7 20:51:38.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.97.65.210 peer_port: 5246
*Nov  7 20:52:01.751:  Mesh setting the ethernet port 0 state to 2
*Nov  7 20:52:02.751: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.97.65.210:5246
*Nov  7 20:52:02.751: %MESH-6-CAPWAP_RESTART: Mesh Capwap re-started
*Nov  7 20:52:02.751: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Nov  7 20:51:38.439: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.97.65.210 peer_port: 5246
*Nov  7 20:51:38.439: %CAPWAP-5-SENDJOIN: sending Join Request to 10.97.65.210
*Nov  7 20:51:38.439: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination.
*Nov  7 20:51:38.439: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 10 state 5.
*Nov  7 20:51:38.439: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Nov  7 20:51:43.439: %CAPWAP-5-SENDJOIN: sending Join Request to 10.97.65.210
*Nov  7 20:52:37.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.97.65.210:5246
*Nov  7 20:52:38.031: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Nov  7 20:52:38.083: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Nov  7 20:52:38.119: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Nov  7 20:52:39.083: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Nov  7 20:52:39.139: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Nov  7 20:52:40.139: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Nov  7 20:52:48.079: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Nov  7 20:53:10.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.97.65.210 peer_port: 5246
*Nov  7 20:53:10.439: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.97.65.210 peer_port: 5246
*Nov  7 20:53:10.439: %CAPWAP-5-SENDJOIN: sending Join Request to 10.97.65.210
*Nov  7 20:53:10.439: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination.
*Nov  7 20:53:10.439: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 10 state 5.
*Nov  7 20:53:10.439: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Nov  7 20:53:10.439: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap packet from 10.97.65.210
*Nov  7 20:53:15.439: %CAPWAP-5-SENDJOIN: sending Join Request to 10.97.65.210
*Nov  7 20:54:09.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.97.65.210:5246
*Nov  7 20:54:10.031: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Nov  7 20:54:10.083: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Nov  7 20:54:10.119: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Nov  7 20:54:11.083: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Nov  7 20:54:11.139: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Nov  7 20:54:12.139: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Nov  7 20:54:20.079: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Nov  7 20:54:18.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.97.65.210 peer_port: 5246
*Nov  7 20:54:18.435: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.97.65.210 peer_port: 5246
*Nov  7 20:54:18.439: %CAPWAP-5-SENDJOIN: sending Join Request to 10.97.65.210
*Nov  7 20:54:18.439: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination.
*Nov  7 20:54:18.439: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 10 state 5.
*Nov  7 20:54:18.439: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Nov  7 20:54:18.439: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap packet from 10.97.65.210
*Nov  7 20:54:23.439: %CAPWAP-5-SENDJOIN: sending Join Request to 10.97.65.210
*Nov  7 20:54:27.839: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join timer expired
*Nov  7 20:54:27.839: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join failed expired
*Nov  7 20:54:27.839:  Mesh setting the ethernet port 0 state to 0
*Nov  7 20:54:27.839: %MESH-6-LINK_UPDOWN: Mesh station 78da.6e60.914c link Down
*Nov  7 20:55:02.923: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Nov  7 20:55:02.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.97.65.210 peer_port: 5246
*Nov  7 20:55:02.439: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.97.65.210 peer_port: 5246
*Nov  7 20:55:02.439: %CAPWAP-5-SENDJOIN: sending Join Request to 10.97.65.210
*Nov  7 20:55:02.439: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination.
*Nov  7 20:55:02.439: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 10 state 5.
*Nov  7 20:55:02.439: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Nov  7 20:55:02.439: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap packet from 10.97.65.210
*Nov  7 20:55:07.439: %CAPWAP-5-SENDJOIN: sending Join Request to 10.97.65.210
*Nov  7 20:56:01.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.97.65.210:5246
*Nov  7 20:56:02.031: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Nov  7 20:56:02.083: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to downST
*Nov  7 20:56:02.119: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Nov  7 20:57:09.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.        97.65.210:5246
*Nov  7 20:57:10.031: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led sta        te 255
*Nov  7 20:57:10.083: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to do        wn
*Nov  7 20:57:10.119: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to r        eset
*Nov  7 20:57:11.083: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio        0, changed state to down
*Nov  7 20:57:11.139: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Nov  7 20:57:12.139: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio        0, changed state to up
*Nov  7 20:57:19.835: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join timer expired
*Nov  7 20:57:19.835: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join failed expired
*Nov  7 20:57:19.835:  Mesh setting the ethernet port 0 state to 0
*Nov  7 20:57:19.835: %MESH-6-LINK_UPDOWN: Mesh station 78da.6e60.914c link Down
*Nov  7 20:57:20.083: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Nov  7 20:57:18.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i        p: 10.97.65.210 peer_port: 5246
*Nov  7 20:57:41.751:  Mesh setting the ethernet port 0 state to 2
*Nov  7 20:57:42.751: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.        97.65.210:5246
*Nov  7 20:57:42.751: %MESH-6-CAPWAP_RESTART: Mesh Capwap re-started
*Nov  7 20:57:42.751: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Nov  7 20:57:18.439: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully        peer_ip: 10.97.65.210 peer_port: 5246
*Nov  7 20:57:18.439: %CAPWAP-5-SENDJOIN: sending Join Request to 10.97.65.210
*Nov  7 20:57:18.439: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination        .
*Nov  7 20:57:18.439: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process m        essage type 10 state 5.
*Nov  7 20:57:18.439: %CAPWAP-3-ERRORLOG: Failed to handle capwap control messag        e from controller
*Nov  7 20:57:23.439: %CAPWAP-5-SENDJOIN: sending Join Request to 10.97.65.210
*Nov  7 20:58:17.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.        97.65.210:5246
*Nov  7 20:58:18.031: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led sta        te 255
*Nov  7 20:58:18.083: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to do        wn
*Nov  7 20:58:18.119: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to r        eset
*Nov  7 20:58:19.083: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio        0, changed state to down
*Nov  7 20:58:19.139: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Nov  7 20:58:20.139: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio        0, changed state to up
*Nov  7 20:58:28.079: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Nov  7 20:58:50.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i        p: 10.97.65.210 peer_port: 5246
*Nov  7 20:58:50.439: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully        peer_ip: 10.97.65.210 peer_port: 5246
*Nov  7 20:58:50.439: %CAPWAP-5-SENDJOIN: sending Join Request to 10.97.65.210
*Nov  7 20:58:50.439: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination        .
*Nov  7 20:58:50.439: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process m        essage type 10 state 5.
*Nov  7 20:58:50.439: %CAPWAP-3-ERRORLOG: Failed to handle capwap control messag        e from controller
*Nov  7 20:58:50.439: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap pac        ket from 10.97.65.210
*Nov  7 20:58:55.439: %CAPWAP-5-SENDJOIN: sending Join Request to 10.97.65.210
*Mar  1 00:01:39.463: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
*Mar  1 00:01:49.463: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Nov  7 21:09:25.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.97.65.210 peer_port: 5246
*Nov  7 21:09:26.439: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.97.65.210 peer_port: 5246
*Nov  7 21:09:26.439: %CAPWAP-5-SENDJOIN: sending Join Request to 10.97.65.210
*Nov  7 21:09:26.439: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination.
*Nov  7 21:09:26.439: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 10 state 5.
*Nov  7 21:09:26.439: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Nov  7 21:09:26.439: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap packet from 10.97.65.210
*Nov  7 21:09:31.439: %CAPWAP-5-SENDJOIN: sending Join Request to 10.97.65.210
*Nov  7 21:10:24.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.97.65.210:5246
*Nov  7 21:10:25.031: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Nov  7 21:10:25.079: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Nov  7 21:10:25.119: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Nov  7 21:10:26.079: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Nov  7 21:10:26.139: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Nov  7 21:10:27.139: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Nov  7 21:10:35.079: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Nov  7 21:10:33.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.97.65.210 peer_port: 5246
*Nov  7 21:10:33.439: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.97.65.210 peer_port: 5246
*Nov  7 21:10:33.443: %CAPWAP-5-SENDJOIN: sending Join Request to 10.97.65.210
*Nov  7 21:10:33.443: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination.
*Nov  7 21:10:33.443: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 10 state 5.
*Nov  7 21:10:33.443: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Nov  7 21:10:33.443: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap packet from 10.97.65.210
*Nov  7 21:10:38.439: %CAPWAP-5-SENDJOIN: sending Join Request to 10.97.65.210
*Nov  7 21:11:14.163: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join timer expired
*Nov  7 21:11:14.163: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join failed expired
*Nov  7 21:11:14.163:  Mesh setting the ethernet port 0 state to 0
*Nov  7 21:11:14.163: %MESH-6-LINK_UPDOWN: Mesh station 78da.6e60.914c link Down
The WLC version 7.6.130
1 ACCEPTED SOLUTION
VIP Purple
Hi Given 1532 came up with a
Given 1532 came up with a mesh image.
To get it register, you have to add its Ethernet MAC address to AP Policies (Securities -> AP Policies -> Add ). Once you do this AP will register as bridge mode AP & then you can convert it to local mode or any other mode as you required.
Rasika
**** Pls rate all useful responses ****
VIP Purple
Rasika
Community Member
Excellent!  I could not find
Excellent!  I could not find this in the Getting Started Guide or Installation Guide.  In what document is this located?
VIP Purple
Hi Jeffrey,I do not think it
Hi Jeffrey,
I do not think it is documented in config guide or getting started guide.
In troubleshoot tech notes you can find it. See below
https://supportforums.cisco.com/document/69341/ap-fails-join-controller-lap-fails-join-wireless-lan-controller-wlc#Troubleshooting_Scenario_7
Rasika
941
