ap 1552 can not up dot radio
Hi my name is Ivan, I have an issue with one ap 1552
Ths interface dot radio b,g,n is down  but a/n/ac is up,
Plase coul you help me to resolv this issue?
Mar  1 00:00:15.795: %SNMP-5-COLDSTART: SNMP agent on host AP322 is undergoing a cold start
*Mar  1 00:00:16.075: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:00:16.075: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar  1 00:00:17.711: %CDP_PD-2-POWER_LOW: All radios disabled - INJECTOR_DETECTED
*Mar  1 00:00:18.547: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet4, changed state to up
*Mar  1 00:00:19.199: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:19.199: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  1 00:00:37.203: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER.xxxxxxxxx
*Mar  1 00:00:37.203: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Mar  1 00:00:37.271: Starting Ethernet promiscuous mode
*Mar  1 00:00:37.435: %SSH-5-ENABLED: SSH 2.0 has been enabledlwapp_crypto_init: MIC Present and Parsed Successfully
*Mar  1 00:00:37.523: Logging LWAPP message to 255.255.255.255.
*Mar  1 00:00:38.459: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:00:38.467: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Mar  1 00:00:38.475: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar  1 00:00:39.495: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:00:40.495: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Mar  1 00:01:05.539: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER.xxxxxxx
*Mar  1 00:01:16.539: %CAPWAP-3-ERRORLOG: Selected MWAR 'WLC301'(index 0).
*Mar  1 00:01:16.539: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Feb 13 18:50:01.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.144.81.10 peer_port: 5246
*Feb 13 18:50:01.583: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.144.81.10 peer_port: 5246
*Feb 13 18:50:01.583: %CAPWAP-5-SENDJOIN: sending Join Request to 10.144.81.10
*Feb 13 18:50:01.587: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination.
*Feb 13 18:50:01.587: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 10 state 5.
*Feb 13 18:50:01.587: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Feb 13 18:50:01.587: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap packet from 10.144.81.10
*Feb 13 18:50:01.675: Starting Ethernet promiscuous mode
*Feb 13 18:50:04.739: ac_first_hop_mac - IP:10.144.81.10 Hop IP:10.144.81.10 IDB:BVI1
*Feb 13 18:50:04.743: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Feb 13 18:50:04.751: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Feb 13 18:50:05.939: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Feb 13 18:50:05.939: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Feb 13 18:50:06.015: %LWAPP-4-CLIENTEVENTLOG: OfficeExtend Localssid saved in AP flash
*Feb 13 18:50:06.031: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Feb 13 18:50:06.039: %DOT11-6-DFS_SCAN_START: DFS: Scanning frequency 5280 MHz for 60 seconds.
*Feb 13 18:50:06.051: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Feb 13 18:50:06.051: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Feb 13 18:50:06.059: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Feb 13 18:50:07.111: %CAPWAP-5-JOINEDCONTROLLER: AP has joined controller WLC301
*Feb 13 18:50:07.155: %LWAPP-4-CLIENTEVENTLOG: No Flex ACL map configuration file to load. Connect to controller to get configuration file
*Feb 13 18:50:07.155: %LWAPP-4-CLIENTEVENTLOG: No LS Flex ACL map configuration file to load. Connect to controller to get configuration file
*Feb 13 18:50:07.155: %LWAPP-4-CLIENTEVENTLOG: No Central Dhcp map configuration file to load. Connect to controller to get configuration fileWLAN id 1, SSID WF_ADMINISTRATIVOS, L2ACL , L2ACL AP
WLAN id 2, SSID WF_ALUMNOS, L2ACL , L2ACL AP
*Feb 13 18:50:07.291: %DOT11-6-DFS_SCAN_START: DFS: Scanning frequency 5280 MHz for 60 seconds.
*Feb 13 18:50:07.295: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Feb 13 18:50:08.487: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Feb 13 18:50:08.623: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Feb 13 18:50:08.627: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Feb 13 18:50:09.727: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Feb 13 18:50:09.887: %DOT11-6-DFS_SCAN_START: DFS: Scanning frequency 5280 MHz for 60 seconds.
*Feb 13 18:50:09.891: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Feb 13 18:50:09.899: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Feb 13 18:50:09.907: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
Hall of Fame Super Gold
IF you have a WLC, can you post the following output:
1.  WLC:  sh sysinfo;
2.  AP:  sh version
Hi leo laohoo
show sysinfo
air-ct-5508-25-k9 ver 7.5.102.0
show ver
air-ap1552-a-k9
regards
Re: ap 1552 can not up dot radio
show sysinfo
show ver
air-ap1552-a-k9
Ivan,
You are NOT helping.
Please furnish the COMPLETE output as requested.
Are you using standard power injector (AIR-PWRINJ1500-2=) that came from 1552?
Or perhaps using other type of cisco injectors?
Please take note of the following:
The 1550 series access point supports these power sources:
•AC power—100 to 480 VAC, models 1552E and 1552EU access points, pole-mount configuration
•AC power—100 to 277 VAC, model 1552I access point
•Power-over-Cable (POC)—40 to 90 VAC, quasi-square wave AC, models 1552C and 1552CU (standard power source for the cable modem configuration)
•External 12 VDC
•Power-over-Ethernet (PoE)—56 VDC power injector (AIR-PWRINJ1500-2=), only on models 1552E and 1552EU access points
•Internal 6 ampere-hour battery backup—only for the 1552E and 1552EUaccess point
The 1550 series access point can be connected to more than one power source. The access point detects available input sources and switches to the preferred power source using the following prioritization:
•AC power or POC power
•External 12-VDC power
•Power injector PoE power
•Internal battery power
420
