ap 1552 can't join to wlc5508
I try to join ap1552 with power injector to wlc 5508. AP gets ip but i don't see anything more. No logs on wlc. It looks that ap even don't try to connect.
I checked Debug Capwap Events,  Debug Capwap Errors, Debug Capwap Details,  with filter for my AP mac address and there is nothing, no try to connect, no errors. Maybe it's a problem with power ? bacause i see that radio interfaces are down. Maybe if there is no power enough, AP don't try to join ?I Use ftp 5e, 2m,10m,25m between power injector and AP.  Thanks for any support, greetings, Peter
my output:
(Cisco Controller) >show debug
MAC address ................................ 50:17:ff:dc:85:e0
Debug Flags Enabled:
capwap detail enabled.
capwap error enabled.
capwap info enabled.
capwap critical enabled.
capwap events enabled.
capwap state enabled.
dhcp packet enabled.
dot11 mobile enabled.
dot11 state enabled
dot1x events enabled.
dot1x states enabled.
lwapp events enabled.
lwapp errors enabled.
lwapp detail enabled.
pem events enabled.
pem state enabled.
CCKM client debug enabled.
(Cisco Controller) >show inventory
Burned-in MAC Address............................ CC:EF:48:B3:90:20
Power Supply 1................................... Present, OK
Power Supply 2................................... Absent
Maximum number of APs supported.................. 50
NAME: "Chassis"    , DESCR: "Cisco 5500 Series Wireless LAN Controller"
PID: AIR-CT5508-K9,  VID: V02,  SN: FCW1548L0EH
(Cisco Controller) >show time
Time............................................. Sat Nov 16 13:05:22 2013
Timezone delta................................... 1:0
Timezone location................................
NTP Servers
NTP Polling Interval.........................     3600
Index     NTP Key Index     NTP Server      NTP Msg Auth Status
2              0       1.1.1.41       AUTH DISABLED
ap>show version
Cisco IOS Software, C1550 Software (C1520-K9W7-M), Version 15.2(2)JB, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 11-Dec-12 05:12 by prod_rel_team
ROM: Bootstrap program is C1550 boot loader
BOOTLDR: C1550 Boot Loader (C1520-BOOT-M) LoaderVersion 15.2(2a)JA, RELEASE SOFTWARE (fc1)
ap uptime is 2 minutes
System returned to ROM by power loss
System image file is "flash:/c1520-k9w7-mx.152-2.JB/c1520-k9w7-xx.152-2.JB"
Last reload reason:
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 50:17:FF:DC:85:E0
Part Number                          : 73-13538-02
PCA Assembly Number                  : 800-31224-01
PCA Revision Number                  : 03
PCB Serial Number                    : FOC173823JV
Top Assembly Part Number             : 800-34853-05
Top Assembly Serial Number           : FCZ1743H03L
Top Revision Number                  : A0
Product/Model Number                 : AIR-CAP1552E-E-K9
ap>sh inventory
NAME: "AP1550", DESCR: "Cisco Aironet 1550 Series (IEEE 802.11n) Access Point"
PID: AIR-CAP1552E-E-K9 , VID: V04, SN: FCZ1743H03L
ap>sh ip interface brief
Interface                  IP-Address      OK? Method Status                Protocol
BVI1                       1.1.1.115 YES DHCP   up                    up
Dot11Radio0                unassigned      YES unset  administratively down down
Dot11Radio1                unassigned      YES unset  administratively down down
GigabitEthernet0           unassigned      YES TFTP   up                    up
GigabitEthernet1           unassigned      YES unset  up                    down
GigabitEthernet2           unassigned      YES unset  up                    down
GigabitEthernet3           unassigned      YES unset  up                    down
ap>
ap>show evtlog
Current evtlog contents:
Mar 1 00:00:14.475: %EVT-5-NTC: Unable to open event log file flash:/event.log
Mar 1 00:00:14.475: %EVT-5-NTC: Read and initialized AP event log (contains, 0 messages)
Mar 1 00:00:24.095: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet4, changed state to up
Mar 1 00:00:26.107: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
Mar 1 00:01:21.715: %EVT-5-NTC: Radio d0 RST 37 Flags 60109 BCN 0
Mar 1 00:01:21.719: %EVT-5-NTC: Radio d0 RST 37 Flags 60109 BCN 0
Mar 1 00:01:21.719: %EVT-5-NTC: Radio d1 RST 37 Flags 60109 BCN 0
Mar 1 00:01:21.723: %EVT-5-NTC: Radio d1 RST 37 Flags 60109 BCN 0
Mar 1 00:01:21.727: %EVT-5-NTC: Radio d0 RST 54 Flags 60109 BCN 0
Mar 1 00:01:21.727: %EVT-5-NTC: Radio d1 RST 54 Flags 60109 BCN 0
Mar 1 00:01:21.731: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
Mar 1 00:01:21.731: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
Mar 1 00:01:28.759: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C1550 Software (C1520-K9W7-M), Version 15.2(2)JB, RMar 1 00:01:28.759: %SNMP-5-COLDSTART: SNMP agent on host ap is undergoing a cold start
Mar 1 00:01:28.779: %EVT-5-NTC: Radio d0 RST 37 Flags 60109 BCN 0
Mar 1 00:01:28.779: %EVT-5-NTC: Radio d1 RST 37 Flags 60109 BCN 0
Mar 1 00:01:29.023: %EVT-5-NTC: Radio d0 RST 37 Flags 60109 BCN 0
Mar 1 00:01:29.023: %EVT-5-NTC: Radio d1 RST 37 Flags 60109 BCN 0
Mar 1 00:01:29.743: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
Mar 1 00:01:30.675: %EVT-5-NTC: Radio d1 RST 37 Flags 60109 BCN 0
Mar 1 00:01:30.675: %EVT-5-NTC: Radio d0 RST 37 Flags 60109 BCN 0
Mar 1 00:01:30.675: %CDP_PD-2-POWER_LOW: All radios disabled - INJECTOR_DETECTED
*** End of evtlog ***
2 ACCEPTED SOLUTIONS
Hall of Fame Super Gold
That's not good.
K9W7
I think this is an IOS for AUTONOMOUS.  You need to convert the AP to run CAPWAP.
Post the WLC command of "sh sysinfo".
VIP Purple
As Leo pointed out earlier, you are having Autonomous Image on this AP. So it cannot join to a controller unless you convert this to Lighthweight.
Try to download an Lightweight image like this (c1520-k9w8-tar.152-2.JB.tar) & then using a TFTP server you can upload it to your AP. You can use below command on AP CLI to achieve this.
ap#archive download-sw /force-reload /overwrite tftp://x.x.x.x/c1520-k9w8-tar.152-2.JB.tar
Once you do this conversion your AP should be able to join the WLC
Rasika
**** Pls rate all useful responses ****
That's not good.
K9W7
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.0.220.0
Bootloader Version............................... 1.0.1
Field Recovery Image Version..................... 6.0.182.0
Firmware Version................................. FPGA 1.3, Env 1.6, USB console 1.27
Build Type....................................... DATA + WPS
System Name...................................... WLC1T
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
IP Address....................................... 1.1.1.10
Last Reset....................................... Software reset
System Up Time................................... 0 days 0 hrs 16 mins 44 secs
System Timezone Location.........................
Current Boot License Level....................... base
Current Boot License Type........................ Permanent
Next Boot License Level.......................... base
Next Boot License Type........................... Permanent
--More-- or (q)uit
Configured Country............................... PL
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +37 C
External Temperature............................. +20 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 5
Number of Active Clients......................... 18
Did you assign the MAC address of the 1552 into the WLC?
I have also in log:
*spamApTask0: Nov 16 14:11:54.765: %LWAPP-3-DISC_INTF_STATE_ERR: spam_lrad.c:17415 Unable to get administrative state of interface 'ap-manager' (port 0), not returning interface in discovery response
but i'm not sure that is connected with my problem..
Please post the WLC command of "sh sysinfo".
VIP Purple
Rasika
I change software as You said and it works! Thanks for help.
I noticed also that AP1552 can only works in bridge mode, rest of my AP are in local mode. I hope that they will work together without problems..
Second point is that i had to add my AP1552 mac address to SECURITY > MAC Filtering. For rest of my old AP 11xx,12xx i didn't have to add mac address there. I don't understand this..
VIP Purple
This mean your AP is having mesh image. For that to work you need to add this MAC entry  & cisco may remove this restriction in future.
You should be able to change this to local mode AP. Did you try to change (in WLC GUI Wireless -> AP -> General -> AP mode -> set to Local) the AP mode into local ? That should work.
In local mode you do not want to have this MAC entry
Rasika
834
