AP 1552E Lightweight not joining WLC
I have a WLC 5508 network that works well with 1200 Series APs and now we got a 1552E AP that is in lightweight mode but doesnt join the WLC.
The AP seems to be able to get to the WLC but some how the connection is not established fully, I suspect maybe the encapsulation could be the problem let me know if you have an idea. The WLC ip is 192.168.0.17 while the AP has a static IP of 192.168.0.123.
*Feb 10 14:49:29.711: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.0.17
*Feb 10 14:49:29.711: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Feb 10 14:49:29.715: %DTLS-5-ALERT: Received WARNING : Close notify alert from 192.168.0.17
*Feb 10 14:49:29.715: %DTLS-5-PEER_DISCONNECT: Peer 192.168.0.17 has closed connection.
*Feb 10 14:49:29.715: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.0.17:5246
*Feb 10 14:49:29.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.0.17 peer_port: 5246
*Feb 10 14:49:29.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Feb 10 14:49:29.711: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 192.168.0.17 peer_port: 5246
*Feb 10 14:49:29.711: %DTLS-5-ALERT: Received WARNING : Close notify alert from 192.168.0.17
*Feb 10 14:49:29.711: %DTLS-5-PEER_DISCONNECT: Peer 192.168.0.17 has closed connection.
*Feb 10 14:49:29.711: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.0.17:5246
*Feb 10 14:49:29.755: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Feb 10 14:49:29.835:  status of voice_diag_test from WLC is false
*Feb 10 14:49:42.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.0.17 peer_port: 5246
*Feb 10 14:49:42.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Feb 10 14:49:42.711: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 192.168.0.17 peer_port: 5246
*Feb 10 14:49:42.715: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.0.17
*Feb 10 14:49:42.715: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Feb 10 14:49:42.715: %DTLS-5-ALERT: Received WARNING : Close notify alert from 192.168.0.17
*Feb 10 14:49:42.715: %DTLS-5-PEER_DISCONNECT: Peer 192.168.0.17 has closed connection.
*Feb 10 14:49:42.715: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.0.17:5246
% CDP is not supported on this interface, or for this encapsulationg Join Request to 192.168.0.17 *Feb 10 14:49:29.711: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.0.17
Kindly let me know if you have ever faced such a problem.
VIP Purple
paste the output of these commands.
From wlc: sh sysinfo
From AP: sh version
Dont forget to rate helpfuil posts
Cisco IOS Software, C1550 Software (C1520-K9W8-M), Version 12.4(23c)JA2, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 13-Apr-11 13:15 by prod_rel_team
ROM: Bootstrap program is C1550 boot loader
BOOTLDR: C1550 Boot Loader (C1520-BOOT-M) LoaderVersion 15.2(2a)JA, RELEASE SOFTWARE (fc1)
AP04da.d21f.a8c0 uptime is 29 minutes
System returned to ROM by reload
System image file is "flash:/c1520-k9w8-mx.124-23c.JA2/c1520-k9w8-mx.124-23c.JA2"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP1552SA-E-K9   (PowerPC 8349) processor (revision A0) with 49142K/16384K bytes of memory.
Processor board ID FGL1706Y03G
PowerPC 8349 CPU at 533Mhz, revision number 0x0031
Last reset from reload
LWAPP image version 7.0.112.74
AVR Microcontroller 1 - SW Version: 00.01.02
AVR Microcontroller 2 - SW Version: 00.01.09
AVR Microcontroller 6 - SW Version: 00.01.00
4 Gigabit Ethernet interfaces
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Part Number                          : 73-13538-02
PCA Assembly Number                  : 800-31224-01
PCA Revision Number                  : 03
PCB Serial Number                    : FOC165166Z1
Top Assembly Part Number             : 800-35281-02
Top Assembly Serial Number           : FGL1706Y03G
Top Revision Number                  : A0
Product/Model Number                 : AIR-CAP1552SA-E-K9
Configuration register is 0xF
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.3.112.0
Bootloader Version............................... 1.0.1
Field Recovery Image Version..................... 6.0.182.0
Firmware Version................................. FPGA 1.3, Env 1.6, USB console 1.27
Build Type....................................... DATA + WPS
System Name...................................... CISCO-LWAPP-CONTROLLER
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
Redundancy Mode.................................. Disabled
IP Address....................................... 10.131.228.17
Last Reset....................................... Power on reset
System Up Time................................... 7 days 6 hrs 49 mins 24 secs
System Timezone Location.........................
Configured Country............................... Multiple Countries:GB,KN
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +34 C
--More-- or (q)uit
External Temperature............................. +18 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 3
Number of Active Clients......................... 5
Burned-in MAC Address............................ F8:66:F2:FA:64:60
Power Supply 1................................... Present, OK
Power Supply 2................................... Absent
Maximum number of APs supported.................. 50
VIP Purple
please add AP MAC address in AP policies as per my last post.
Dont forget to rate helpful posts
VIP Purple
Did you add the AP MAC to your AP Policies section of the WLC???
For a mesh access point to connect to a Cisco wireless LAN controller, you need to add the access point to the controller's MAC filtering list.
To add the access point to a controller's MAC filtering list, do one of the following:
In the Web user interface of the controller, choose the MAC filtering option (Security > AAA > MAC Filtering) and manually add the mesh access points.
I have added it t the MAC Filter and restarted the AP and still its not registering.
Is there anything else we need to add?
VIP Purple
paste the full logs after adding mac address.....
If you still facing problem then ..you can come on teamviewer, I can check remotely(Only if you want) then you can send me private message your ID and paswd for Teamviewer.
The IP of the AP is 10.131.228.72
WLC is 10.131.228.17
(I have moved them to the ive environment so the 192.168.0.1/24 subnet are no longer valid)
The WLC has other APs (1200 series) ad they are OK and even we have some SSIDs that are working.
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (255.255.255.255)
*Mar  1 00:05:09.491: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar  1 00:05:11.567:  status of voice_diag_test from WLC is false
*Feb 14 16:58:39.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.131.228.17 peer_port: 5246
*Feb 14 16:58:39.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Feb 14 16:58:39.711: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.131.228.17 peer_port: 5246
*Feb 14 16:58:39.711: %CAPWAP-5-SENDJOIN: sending Join Request to 10.131.228.17
*Feb 14 16:58:39.711: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Feb 14 16:58:39.715: %DTLS-5-ALERT: Received WARNING : Close notify alert from 10.131.228.17
*Feb 14 16:58:39.715: %DTLS-5-PEER_DISCONNECT: Peer 10.131.228.17 has closed connection.
*Feb 14 16:58:39.715: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.131.228.17:5246
*Feb 14 16:58:39.715: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.131.228.
Translating "CISCO-LWAPP-CONTROLLER"...domain server (255.255.255.255)
17 peer_port: 5246
*Feb 14 16:58:39.715: %CAPWAP-5-SENDJOIN: sending Join Request to 10.131.228.17
*Feb 14 16:58:39.715: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Feb 14 16:58:39.707: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.131.228.17 peer_port: 5246
*Feb 14 16:58:39.707: %CAPWAP-5-SENDJOIN: sending Join Request to 10.131.228.17
*Feb 14 16:58:39.707: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Feb 14 16:58:39.711: %DTLS-5-ALERT: Received WARNING : Close notify alert from 10.131.228.17
*Feb 14 16:58:39.711: %DTLS-5-PEER_DISCONNECT: Peer 10.131.228.17 has closed connection.
*Feb 14 16:58:39.711: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.131.228.17:5246
*Feb 14 16:58:39.755: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Feb 14 16:58:39.839:  status of voice_diag_test from WLC is false
*Feb 14 16:58:51.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.131.228.17 peer_port: 5246
*Feb 14 16:58:51.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Feb 14 16:58:51.707: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.131.228.17 peer_port: 5246
*Feb 14 16:58:51.711: %CAPWAP-5-SENDJOIN: sending Join Request to 10.131.228.17
*Feb 14 16:58:51.711: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Feb 14 16:58:51.711: %DTLS-5-ALERT: Received WARNING
*Feb 14 16:58:51.711: %DTLS-5-PEER_DISCONNECT: Peer 10.131.228.17 has closed connection.
*Feb 14 16:58:51.711: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.131.228.17:5246
*Feb 14 16:58:51.711: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.131.228.17 peer_port: 5246
*Feb 14 16:58:51.711: %DTLS-5-ALERT: Received WARNING : Close notify alert from 10.131.228.17
*Feb 14 16:58:51.707: %CAPWAP-5-SENDJOIN: sending Join Request to 10.131.228.17
*Feb 14 16:58:51.707: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Feb 14 16:58:51.755: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Feb 14 16:58:51.839:  status of voice_diag_test from WLC is false
VIP Purple
Re: AP 1552E Lightweight not joining WLC
ohhhhhh shit..............How can i forget that mesh AP will join only with single country configured WLC>
you have configured two countries on wlc:
This AP will not join if you configured mulilpe country on WLC.
Make only one country on wlc and then try,
It downloaded the image from the WLC but still am getting this error
  2F455CFF 4552ECDB 5667E3FC E7093E06 8FAE353D 4228B48D 8B415D9B F496342D
  C1459987 B69BFA4B 51FB67B4 A0C21E7F C6269A39 47EB1D48 5E83B129 8B079E5E
  1EDAB5A0 BE5E1DE0 109FF0BD 4750E32B 02030100 01A38201 37308201 33300C06
  03551D13 04053003 0101FF30 2E060960 86480186 F842010D 0421161F 41697265
  73706163 65204465 76696365 20434120 43657274 69666963 61746530 1D060355
  1D0E0416 04140A52 3BB12570 523B9CEA 747FB2AD 3D8F95EA 3FCC3081 D3060355
  1D230481 CB3081C8 8014538D 8360478D C20F8066 3232E9E1 7070552B 17EAA181
  ACA481A9 3081A631 0B300906 03550406 13025553 31133011 06035504 08130A43
  616C6966 6F726E69 61311130 0F060355 04071308 53616E20 4A6F7365 31173015
  06035504 0A130E41 69726573 70616365 20496E63 2E311430 12060355 040B130B
  456E6769 6E656572 696E6731 1A301806 03550403 13114169 72657370 61636520
  526F6F74 20434131 24302206 092A8648 86F70D01 09011615 73757070 6F727440
  61697265 73706163 652E636F 6D820100 300D0609 2A864886 F70D0101 04050003
  81C100A0 E8D59D9B DA9EED0C 96045DFE A37084EC 59B5C3D3 71694DB0 70664E0C
  8060D69E E366E81F 9F3CCF68 8AB0498E CCFA6CA7 2854F2D8 046690C9 8FEC84EF
  2F7F0F08 C90F719D C0F4C125 CED1B525 6DD93E51 777BD5E8 7F1DC79F CC502DC2
  0242C05D 1682DEE3 DF7541B8 C55B433C 10DFE2BF D2E802E7 D923329A 23A2076F
  86BCC048 D569B383 59AC8979 97F02C55 6F8FE318 754F605C 43CDA7C8 1847B085
  1DADF0D6 CD62C8DE A86E6E12 4A7CDCBF A6FCC7E1 852A1DB1 529D63B3 688305F6 7BD25F
        quit
crypto pki certificate chain cisco-root-cert
certificate ca 5FF87B282B54DC8D42A315B568C9ADFF
  30820343 3082022B A0030201 0202105F F87B282B 54DC8D42 A315B568 C9ADFF30
  0D06092A 864886F7 0D010105 05003035 31163014 06035504 0A130D43 6973636F
  20537973 74656D73 311B3019 06035504 03131243 6973636F 20526F6F 74204341
  20323034 38301E17 0D303430 35313432 30313731 325A170D 32393035 31343230
  32353432 5A303531 16301406 0355040A 130D4369 73636F20 53797374 656D7331
  1B301906 03550403 13124369 73636F20 526F6F74 20434120 32303438 30820120
  300D0609 2A864886 F70D0101 01050003 82010D00 30820108 02820101 00B09AB9
  ABA7AF0A 77A7E271 B6B46662 94788847 C6625584 4032BFC0 AB2EA51C 71D6BC6E
  7BA8AABA 6ED21588 48459DA2 FC83D0CC B98CE026 68704A78 DF21179E F46105C9
  15C8CF16 DA356189 9443A884 A8319878 9BB94E6F 2C53126C CD1DAD2B 24BB31C4
  2BFF8344 6FB63D24 7709EABF 2AA81F6A 56F6200F 11549781 75A725CE 596A8265
  EFB7EAE7 E28D758B 6EF2DD4F A65E629C CF100A64 D04E6DCE 2BCC5BF5 60A52747
  8D69F47F CE1B70DE 701B20D6 6ECDA601 A83C12D2 A93FA06B 5EBB8E20 8B7A91E3
  B568EEA0 E7C40174 A8530B2B 4A9A0F65 120E824D 8E63FDEF EB9B1ADB 53A61360
  AFC27DD7 C76C1725 D473FB47 64508180 944CE1BF AE4B1CDF 92ED2E05 DF020103
  A351304F 300B0603 551D0F04 04030201 86300F06 03551D13 0101FF04 05300301
  01FF301D 0603551D 0E041604 1427F3C8 151E6E9A 020916AD 2BA08960 5FDA7B2F
  AA301006 092B0601 04018237 15010403 02010030 0D06092A 864886F7 0D010105
  05000382 0101009D 9D8484A3 41A97C77 0CB753CA 4E445062 EF547CD3 75171CE8
  E0C6484B B6FE4C3A 198156B0 56EE1996 62AA5AA3 64C1F64E 5433C677 FEC51CBA
  E55D25CA F5F0939A 83112EE6 CBF87445 FEE705B8 ABE7DFCB 4BE13784 DAB98B97
  701EF0E2 8BD7B0D8 0E9DB169 D62A917B A9494F7E E68E95D8 83273CD5 68490ED4
  9DF62EEB A7BEEB30 A4AC1F44 FC95AB33 06FB7D60 0ADEB48A 63B09CA9 F2A4B953
  0187D068 A4277FAB FFE9FAC9 40388867 B439C684 6F57C953 DBBA8EEE C043B2F8
  09836EFF 66CF3EEF 17B35818 2509345E E3CBD614 B6ECF292 6F74E42F 812AD592
  91E0E097 3C326805 854BD1F7 57E2521D 931A549F 0570C04A 71601E43 0B601EFE
  A3CE8119 E10B35
        quit
crypto pki certificate chain Cisco_IOS_MIC_cert
certificate 2E3E144D0000001BB016
  30820470 30820358 A0030201 02020A2E 3E144D00 00001BB0 16300D06 092A8648
  86F70D01 01050500 30393116 30140603 55040A13 0D436973 636F2053 79737465
  6D73311F 301D0603 55040313 16436973 636F204D 616E7566 61637475 72696E67
  20434130 1E170D31 32313232 36303933 3231365A 170D3232 31323236 30393432
  31365A30 818C310B 30090603 55040613 02555331 13301106 03550408 130A4361
  6C69666F 726E6961 3111300F 06035504 07130853 616E204A 6F736531 16301406
  0355040A 130D4369 73636F20 53797374 656D7331 1B301906 03550403 13124331
  3532302D 30346461 64323166 61386465 3120301E 06092A86 4886F70D 01090116
  11737570 706F7274 40636973 636F2E63 6F6D3082 0122300D 06092A86 4886F70D
  01010105 00038201 0F003082 010A0282 010100B5 1F70C31A E12EDF1A D785A454
  BC6582C5 5AF3CD8D F561B83A 9E83E926 56EF2ABE 27CFF889 F0E13A5E 7EB1C562
  34AA43E8 3E75E2A1 83A27B82 CBE2356F 0842E6D7 887129CB F1FE5558 7A6BF7FF
  229771A2 8B2BBAA9 6678E02D 8073623F 3E5C5A40 07D9B04D 239EAD41 5FC67A59
  B1985F06 7750C5B3 64D2DBD3 66BF2A77 8E2EB7FC 7B3409A8 13BB0422 D10BB367
  FBA72948 58E3AE44 7D1D6483 0C1302F6 7FE49761 CFCE8F35 34647E3B CD5F15E3
  B9EF3B26 F3B09799 2BC6F6C7 41AC6DE1 D048E74D F4F11209 CDE7F377 B4C4A453
  075C9595 E5C61D5F 9F6E2857 AAA5CAF7 0F85DF7F C1B9242A 3AC5FA3F 7324FAE1
  74E39A29 4ABC3FD5 D0F33165 4FD6B75F 000A2902 03010001 A3820124 30820120
  300E0603 551D0F01 01FF0404 030205A0 301D0603 551D0E04 160414AD 5672F62C
  9C862284 6307646C D9E81919 E3123F30 1F060355 1D230418 30168014 D0C52226
  AB4F4660 ECAE0591 C7DC5AD1 B047F76C 303F0603 551D1F04 38303630 34A032A0
  30862E68 7474703A 2F2F7777 772E6369 73636F2E 636F6D2F 73656375 72697479
  2F706B69 2F63726C 2F636D63 612E6372 6C304C06 082B0601 05050701 01044030
  3E303C06 082B0601 05050730 02863068 7474703A 2F2F7777 772E6369 73636F2E
  636F6D2F 73656375 72697479 2F706B69 2F636572 74732F63 6D63612E 63657230
  3F06092B 06010401 82371402 04321E30 00490050 00530045 00430049 006E0074
  00650072 006D0065 00640069 00610074 0065004F 00660066 006C0069 006E0065
  300D0609 2A864886 F70D0101 05050003 82010100 0B5F8FF4 3EAF5A8C 7663D5FB
  16BC2823 4F37FE4A DBB26CDC E779C6D6 8A5CDC54 FACAFDE5 F07A8EC8 F44C07B6
  C0405359 F4CC7369 3763D8D5 AFAC720A 03C958F7 3745035D EF35D346 FCCFC6D9
  604506EE 52C85FDA FA9880FB 6D28C6A5 36D28A0E B97C8DBA 5E511196 C1263F23
  6EF77F60 84AE984F E2B3FF43 700F45FB D78FAA0E D44E3AA7 1014C824 43B11AAF
  03DB7D19 11A8E4AB 8E5EB734 FF7FAFE4 29DC9DB5 82FEBE26 EC39A005 CFD243E9
  8A19D74E A759EDC5 A2788B60 103480FB E7AF1D19 8AFE463E AF6C8CE6 90154ABB
  85DA3F6E 45A4FE0B 84229452 2871B507 80277B75 BEF926E1 57B2077D 8F15C4BC
  0FB4D661 8A70568A C8E89CB2 FA317D88 E5B7ACA7
        quit
certificate ca 6A6967B3000000000003
  308204D9 308203C1 A0030201 02020A6A 6967B300 00000000 03300D06 092A8648
  86F70D01 01050500 30353116 30140603 55040A13 0D436973 636F2053 79737465
  6D73311B 30190603 55040313 12436973 636F2052 6F6F7420 43412032 30343830
  1E170D30 35303631 30323231 3630315A 170D3239 30353134 32303235 34325A30
  39311630 14060355 040A130D 43697363 6F205379 7374656D 73311F30 1D060355
  04031316 43697363 6F204D61 6E756661 63747572 696E6720 43413082 0120300D
  06092A86 4886F70D 01010105 00038201 0D003082 01080282 010100A0 C5F7DC96
  943515F1 F4994EBB 9B41E17D DB791691 BBF354F2 414A9432 6262C923 F79AE7BB
  9B79E807 294E30F5 AE1BC521 5646B0F8 F4E68E81 B816CCA8 9B85D242 81DB7CCB
  94A91161 121C5CEA 33201C9A 16A77DDB 99066AE2 36AFECF8 0AFF9867 07F430EE
  A5F8881A AAE8C73C 1CCEEE48 FDCD5C37 F186939E 3D71757D 34EE4B14 A9C0297B
  0510EF87 9E693130 F548363F D8ABCE15 E2E8589F 3E627104 8726A415 620125AA
  D5DFC9C9 5BB8C9A1 077BBE68 92939320 A86CBD15 75D3445D 454BECA8 DA60C7D8
  C8D5C8ED 41E1F55F 578E5332 9349D5D9 0FF836AA 07C43241 C5A7AF1D 19FFF673
  99395A73 67621334 0D1F5E95 70526417 06EC535C 5CDB6AEA 35004102 0103A382
  01E73082 01E33012 0603551D 130101FF 04083006 0101FF02 0100301D 0603551D
  0E041604 14D0C522 26AB4F46 60ECAE05 91C7DC5A D1B047F7 6C300B06 03551D0F
  04040302 01863010 06092B06 01040182 37150104 03020100 30190609 2B060104
  01823714 02040C1E 0A005300 75006200 43004130 1F060355 1D230418 30168014
  27F3C815 1E6E9A02 0916AD2B A089605F DA7B2FAA 30430603 551D1F04 3C303A30
  38A036A0 34863268 7474703A 2F2F7777 772E6369 73636F2E 636F6D2F 73656375
  72697479 2F706B69 2F63726C 2F637263 61323034 382E6372 6C305006 082B0601
  05050701 01044430 42304006 082B0601 05050730 02863468 7474703A 2F2F7777
  772E6369 73636F2E 636F6D2F 73656375 72697479 2F706B69 2F636572 74732F63
  72636132 3034382E 63657230 5C060355 1D200455 30533051 060A2B06 01040109
  15010200 30433041 06082B06 01050507 02011635 68747470 3A2F2F77 77772E63
  6973636F 2E636F6D 2F736563 75726974 792F706B 692F706F 6C696369 65732F69
  6E646578 2E68746D 6C305E06 03551D25 04573055 06082B06 01050507 03010608
  2B060105 05070302 06082B06 01050507 03050608 2B060105 05070306 06082B06
  01050507 0307060A 2B060104 0182370A 0301060A 2B060104 01823714 02010609
  2B060104 01823715 06300D06 092A8648 86F70D01 01050500 03820101 0030F330
  2D8CF2CA 374A6499 24290AF2 86AA42D5 23E8A2EA 2B6F6923 7A828E1C 4C09CFA4
  4FAB842F 37E96560 D19AC6D8 F30BF5DE D027005C 6F1D91BD D14E5851 1DC9E3F7
  38E7D30B D168BE8E 22A54B06 E1E6A4AA 337D1A75 BA26F370 C66100A5 C379265B
  A719D193 8DAB9B10 11291FA1 82FDFD3C 4B6E65DC 934505E9 AF336B67 23070686
  22DAEBDC 87CF5921 421AE9CF 707588E0 243D5D7D 4E963880 97D56FF0 9B71D8BA
  6019A5B0 6186ADDD 6566F6B9 27A2EE2F 619BBAA1 3061FDBE AC3514F9 B82D9706
  AFC3EF6D CC3D3CEB 95E981D3 8A5EB6CE FA79A46B D7A25764 C43F4CC9 DBE882EC
  0166D410 88A256E5 3C57EDE9 02A84891 6307AB61 264B1A13 9FE4DCDA 5F
        quit
memory validate-checksum 30
username Cisco secret 5 $1$vM.P$z4SmRayDYBroWLoHcrQvu/
ip ssh version 2
interface Dot11Radio0
no ip route-cache
antenna gain 0
mbssid
power local 3
power client local
packet retries 64 drop-packet
interface Dot11Radio1
no ip route-cache
antenna gain 0
mbssid
power client local
interface GigabitEthernet0
no ip route-cache
duplex full
interface GigabitEthernet1
no ip route-cache
duplex full
interface GigabitEthernet2
no ip route-cache
duplex full
interface GigabitEthernet3
no ip route-cache
duplex full
interface BVI1
ip address dhcp client-id BVI1
no ip route-cache
no ip http server
logging trap emergencies
logging origin-id string AP:04da.d21f.a8c0
logging facility kern
logging snmp-trap notifications
logging snmp-trap informational
logging snmp-trap debugging
logging 255.255.255.255
line con 0
line vty 0 4
transport input none
line vty 5 15
end
AP04da.d21f.a8c0#$
AP04da.d21f.a8c0#
AP04da.d21f.a8c0#
AP04da.d21f.a8c0#
*Feb 14 17:50:02.587: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join timer expired
*Feb 14 17:50:02.587: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join failed expired
*Feb 14 17:50:02.587: %MESH-6-LINK_UPDOWN: Mesh station 04da.d21f.a8de link Down
*Feb 14 17:50:53.591: %MESH-6-CAPWAP_RESTART: Mesh Capwap re-started
*Feb 14 17:50:57.635: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP addre                                                           ss 10.131.228.144, mask 255.255.255.0, hostname AP04da.d21f.a8c0
*Feb 14 17:50:57.635: %MESH-6-CAPWAP_RESTART: Mesh Capwap re-started
*Feb 14 17:51:02.587: %CAPWAP-3-ERRORLOG: Invalid event 29 & state 4 combination                                                           .
*Feb 14 17:51:02.587: %CAPWAP-3-ERRORLOG: SM handler: Failed to process timer me                                                           ssage. Event 29, state 4
*Feb 14 17:51:02.587: %CAPWAP-3-ERRORLOG: Failed to handle timer message.
*Feb 14 17:51:02.587: %CAPWAP-3-ERRORLOG: Failed to process timer message.
*Feb 14 17:51:02.671: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led sta                                                           te 255
Translating "CISCO-CAPWAP-CONTROLLER.ke.batgen.com"...domain server (10.131.228.                                                           50)
*Feb 14 17:51:04.771: %CAPWAP-3-ERRORLOG: Did not get log server settings from D                                                           HCP.
*Feb 14 17:51:05.771: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROL                                                           LER.ke.batgen.com
*Feb 14 17:51:16.771: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Feb 14 17:51:17.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.131.228.17 peer_port:                                5246
*Feb 14 17:51:17.575: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.131.228.17 peer                               _port: 5246
*Feb 14 17:51:17.575: %CAPWAP-5-SENDJOIN: sending Join Request to 10.131.228.17
VIP Purple
pleae confirm.
Do you only have 1 country configured on WLC.
Did you enter the mac address of mesh AP in AP Policiy Section.
If both are done then please reboot the AP and paste the all logs.
These are the only two ways that can stop AP to join WLC.
In the WLC I do not see the option of adding the mac to the policy.
VIP Purple
not here:
. Choose
Security > AP Policies and add AP to the Authorization List
check image. and then try again.
Reagrds
Should I select MIC certificate?
Mine looks different than yours
VIP Purple
Yes , MIC .
The MAC Filter and Policy will not both work so i have to remove one.
VIP Purple
Yes you should have only one.You just need to add mac address in AP Policy.
Thanks i now have the AP Policy only.
The MAC Address has even been reserved on the DHCP server so the IP will remain as .201
Thad does the incorrect led status 255
  --More--
*Mar  1 00:04:26.795: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join timer expired
*Mar  1 00:04:26.795: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join failed expired
*Mar  1 00:04:26.795: %MESH-6-LINK_UPDOWN: Mesh station 04da.d21f.a8de!        n
end
*Mar  1 00:05:17.799: %MESH-6-CAPWAP_RESTART: Mesh Capwap re-started
AP04da.d21f.a8c0#
% CDP is not supported on this interface, or for this encapsulationi
*Mar  1 00:05:22.839: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255nt bv
AP04da.d21f.a8c0#
AP04da.d21f.a8c0#
AP04da.d21f.a8c0#
*Mar  1 00:07:47.799: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join timer expired
*Mar  1 00:07:47.799: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join failed expired
*Mar  1 00:07:47.799: %MESH-6-LINK_UPDOWN: Mesh station 04da.d21f.a8de link Down
*Mar  1 00:08:53.127: %MESH-6-CAPWAP_RESTART: Mesh Capwap re-started
*Mar  1 00:08:58.167: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
VIP Purple
Now I can not findout the error, it will be better to see it.(Teamviewer ,send me private message about id).
Reagrds
I have lost connection to the device, seeems ere is a power problem in the office, i will get it up and running tomorrow and send you the team viewer credentials tomorrow.
VIP Purple
Ok.
321
