AP 1552E NOT JOINING WLC 2504
I am currently having issue relating to my AP not joining the WLC. Have made the WLC the internal DHCP server and the AP has picked an IP Address but the below is what i get from the AP:
*Feb 14 22:48:56.707: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Feb 14 22:48:56.759: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Feb 14 22:48:56.783:  status of voice_diag_test from WLC is false
*Feb 14 22:49:12.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.1.2 peer_port: 5246
*Feb 14 22:49:12.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Feb 14 22:49:12.663: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 192.168.1.2 peer_port: 5246
*Feb 14 22:49:12.663: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.1.2
*Feb 14 22:49:12.663: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Feb 14 22:49:17.663: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.1.2
*Feb 14 22:49:17.663: %DTLS-5-ALERT: Received WARNING : Close notify alert from 192.168.1.2
*Feb 14 22:49:17.663: %DTLS-5-PEER_DISCONNECT: Peer 192.168.1.2 has closed connection.
*Feb 14 22:49:17.663: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.1.2:5246
% CDP is not supported on this interface, or for this encapsulation
*Feb 14 22:49:17.707: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Feb 14 22:49:17.759: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Feb 14 22:49:17.783:  status of voice_diag_test from WLC is false
*Feb 14 22:49:34.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.1.2 peer_port: 5246
*Feb 14 22:49:34.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Feb 14 22:49:34.663: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 192.168.1.2 peer_port: 5246
*Feb 14 22:49:34.663: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.1.2
*Feb 14 22:49:34.663: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Feb 14 22:49:39.663: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.1.2
*Feb 14 22:49:39.663: %DTLS-5-ALERT: Received WARNING : Close notify alert from 192.168.1.2
*Feb 14 22:49:39.663: %DTLS-5-PEER_DISCONNECT: Peer 192.168.1.2 has closed connection.
*Feb 14 22:49:39.663: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.1.2:5246
*Feb 14 22:49:38.591: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join timer expired
*Feb 14 22:49:38.591: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join failed expired
*Feb 14 22:49:38.591: %MESH-6-LINK_UPDOWN: Mesh station f029.29c2.effc link Down
VIP Purple
Your AP has come with MESH image. So you have to add your AP ethernet MAC address to WLC MAC Filter (SECURITY -> MAC Filtering in WLC GUI) & then it should register. Once register, you can change AP mode to Local mode (from Mesh mode)
Rasika
*** Pls rate all useful responses ****
Thanks for the response but i have don't that already. Please the image below.
Two challenges am facing is (1) that i can't seem to be able to access the CLI of my AP because I don't have the login credential (2) Even though i have created the MAC Auth-list on the WLC i am not still able to have the AP join the WLC.
VIP Purple
Re: AP 1552E NOT JOINING WLC 2504
Can you also check the "Accept Manu.. Installed certificate box" and then try again.
If still not works then paste the output of these command:
from WLC: sh sysinfo
From AP: sh version
also paste the entire bootup process from AP console.
Dont forget to rate helpful posts
Hi Sandeep. It seems you are
Hi Sandeep. It seems you are experienced on this. So i will ask you and i hope you will help me.
I have AIR-CT2504-k9 WLC and new 1702i-E-k9 APs. But APs cant join to the controller.
I have upgraded WLC software to the 8.2.111, but no sense.
Hall of Fame Super Silver
You need to make sure you
You need to make sure you have the following:
  • NTP or time set correctly on the controller
  • Country code for -E defined on the controller
  • AP is obtaining a valid up address
Place the AP on the same subnet as the WLC to see if the AP joins.
You also need to console into the AP to really determine what is happening. For example, you can have an issue if the AP is booting in autonomous mode or the AP is setup as a mesh AP.  Console into the AP and attached a text file with the output while booting up the AP.
-Scott
-Scott
Take a look at this guide
Take a look at this guide also:
http://www.cisco.com/c/en/us/support/docs/wireless/5500-series-wireless-controllers/119286-lap-notjoin-wlc-tshoot.html
-Scott
-Scott
Just to add... Here is an older document in regards to MESH troubleshooting. I would look this over also.
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/1500/troubleshooting/guide/TrbleshtMesh.html
Having more info also helps. Do you have any other MESH AP's up? Do you have any AP's up on the WLC? What code are you running on the WLC?
-Scott
Platform: AIR-CT2504-K9, Version :
Manufacturer's Name: Cisco Systems Inc.  Product Name: Cisco Controller  Product Version: 7.0.220.0  RTOS Version: Erro  Bootloader Version: 1.0.18  Build Type: DATA + WPS
Platform: cisco AIR-CAP1552E-E-K9  Version :
Cisco IOS Software, C1550 Software (C1520-K9W8-M), Version 12.4(23c)JA3, RELEASE SOFTWARE (fc1)
Proceeding with system init
Proceeding to unmask interrupts
Initializing flashfs...
flashfs[1]: 22 files, 3 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 31610880
flashfs[1]: Bytes used: 6631936
flashfs[1]: Bytes available: 24978944
flashfs[1]: flashfs fsck took 5 seconds.
flashfs[1]: Initialization complete.
flashfs[2]: 0 files, 1 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 5806080
flashfs[2]: Bytes used: 1024
flashfs[2]: Bytes available: 5805056
flashfs[2]: flashfs fsck took 1 seconds.
flashfs[2]: Initialization complete....done Initializing flashfs.
Warning:  the compile-time code checksum does not appear to be present.
Radio0  present 8364B 8000 A8020000 0 A8030000 30
Radio1  present 8364B 8000 B8020000 0 B8030000 13
Radio2 not present 0 0 0 0 0 11
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
%Error opening flash:/c1520-rcvk9w8-mx/info (No such file or directory)cisco AIR-CAP1552E-E-K9    (PowerPC 8349) processor (revision A0) with 49142K/16384K bytes of memory.
Processor board ID FCZ1718H01Y
PowerPC 8349 CPU at 533Mhz, revision number 0x0031
Last reset from power loss
LWAPP image version 7.0.220.0
4 Gigabit Ethernet interfaces
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: F0:29:29:C2:EF:E0
Part Number                          : 73-13538-02
PCA Assembly Number                  : 800-31224-01
PCA Revision Number                  : 03
PCB Serial Number                    : FOC1705241P
Top Assembly Part Number             : 800-34853-05
Top Assembly Serial Number           : FCZ1718H01Y
Top Revision Number                  : A0
Product/Model Number                 : AIR-CAP1552E-E-K9
% Please define a domain-name first.
Translating "CISCO-LWAPP-CONTROLLER"...domain server (255.255.255.255)
Press RETURN to get started!
*Mar  1 00:00:07.307: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:07.723: m8349_ether_enable: MACCFG1 sync timeout
*Mar  1 00:00:09.819: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:00:09.819: %LINK-3-UPDOWN: Interface Ethernet4, changed state to up
*Mar  1 00:00:09.819: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:09.819: %LINK-3-UPDOWN: Interface GigabitEthernet1, changed state to up
*Mar  1 00:00:09.819: %LINK-3-UPDOWN: Interface GigabitEthernet2, changed state to up
*Mar  1 00:00:09.819: %LINK-3-UPDOWN: Interface GigabitEthernet3, changed state to up
*Mar  1 00:00:11.375: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Mar  1 00:00:11.375: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1, changed state to down
*Mar  1 00:00:11.375: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2, changed state to down
*Mar  1 00:00:11.375: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet3, changed state to down
*Mar  1 00:00:11.963: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1
*Mar  1 00:00:12.039: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 1024 messages)
*Mar  1 00:00:12.051: AP identified to be in Fenway/Huck Jr/1240/1130 configuration
*Mar  1 00:00:12.055:  status of voice_diag_test from WLC is false
*Mar  1 00:00:14.079: %SYS-5-RESTART: System restarted --
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 18-Oct-11 15:13 by prod_rel_team
*Mar  1 00:00:14.079: %SNMP-5-COLDSTART: SNMP agent on host APf029.29c2.efe0 is undergoing a cold start
*Mar  1 00:00:14.143: %MESH-6-BVI_CREATED: Mesh BVI1 interface created
*Mar  1 00:00:14.163: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar  1 00:00:14.163: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:00:15.163: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Mar  1 00:00:15.163: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:00:16.143: %LINK-3-UPDOWN: Interface BVI1, changed state to down
*Mar  1 00:00:17.139: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitE
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (255.255.255.255)thernet0, changed state to down
*Mar  1 00:00:17.143: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1, changed state to down
*Mar  1 00:00:17.143: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2, changed state to down
*Mar  1 00:00:17.143: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet3, changed state to down
*Mar  1 00:00:18.579: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet4, changed state to up
*Mar  1 00:00:20.723: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:32.743: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar  1 00:00:32.795: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Mar  1 00:00:32.959: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 00:00:33.107: Logging LWAPP message to 255.255.255.255.
*Mar  1 00:00:33.307: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 started - CLI initiated
*Mar  1 00:00:46.383: %CDP_PD-2-POWER_LOW: All radios disabled - NEGOTIATED WS-C2960-24PC-S (189c.5d95.2d18)
Username:
*Mar  1 00:01:27.119: %MESH-6-ADJACENCY_STATE_MACHINE_STARTED: Mesh adjacency state machine started
Username:
*Mar  1 00:01:32.163: %MESH-6-CAPWAP_RESTART: Mesh Capwap re-started
*Mar  1 00:01:34.119: %LINK-3-UPDOWN: Interface BVI1, changed state to up
*Mar  1 00:01:35.119: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  1 00:01:37.207: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar  1 00:01:40.887: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Mar  1 00:01:40.907:  status of voice_diag_test from WLC is false
*Mar  1 00:01:46.387: %CDP_PD-2-POWER_LOW: All radios disabled - NEGOTIATED WS-C2960-24PC-S (189c.5d95.2d18)
Obinna Samuel
VIP Purple
paste the output of this command:
sh sysinfo from wlc.
You need to have the correct power injector, AC adapter or hard wired power source to bring up the radios. So don't think this will bring up your MAP. Do you have any other mesh AP's or AP's up in this WLC?
-Scott
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.0.220.0
Bootloader Version............................... 1.0.18
Field Recovery Image Version..................... 1.0.0
Firmware Version................................. PIC 16.0
Build Type....................................... DATA + WPS
System Name...................................... Cisco_43:db:24
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 192.168.1.2
Last Reset....................................... Power on reset
System Up Time................................... 0 days 3 hrs 43 mins 56 secs
System Timezone Location.........................
Current Boot License Level....................... base
Current Boot License Type........................ Permanent
Next Boot License Level.......................... base
--More-- or (q)uit
Next Boot License Type........................... Permanent
Configured Country............................... US  - United States
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +29 C
External Temperature............................. +31 C
Fan Status....................................... 3800 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
Burned-in MAC Address............................ 24:E9:B3:43:DB:20
Maximum number of APs supported.................. 5
VIP Purple
so here is the problem:
you have access point: Product/Model Number                 : AIR-CAP1552E-E-K9
which is for europe regulatery domain and your WLC is configured as USA.
Which country r u in???
dont forget to rate helpful posts
Nigeria which isn't on the country code list.
Does that me i should change the Configured country to an european country since Nigeria isn't on the list?
VIP Purple
If you have diff country then USA then please change it.
How to change country code on WLC:
Step 1  Disable the 802.11 networks as follows:
  1. Choose Wireless > 802.11a/n > Network.
  2. Unselect the 802.11a Network Status check box.
  3. Click Apply.
  4. Choose Wireless > 802.11a/n > Network.
  5. Unselect the 802.11b/g Network Status check box.
  6. Click Apply.
Step 2
Choose Wireless > Country to open the Country page and select the correct country code.
Yes I do have other MAP but not been deployed. trying to see how it works in a lab environment before i go live.
Please tell me if a 2960 PoE switch cannot power the MAP or i need to get a thicker STP Cable?
Obinna Samuel
VIP Purple
Yes you can try that.
VIP Purple
With the -E there are many profiles that can be selected, as most are very close to the same restrictions.
However you should contact to your local regulatory domain group and ask them which country is the same as Nigeria. Explain what you are doing and have them tell you, and get it in writing.  that way you are covered on your choice.
Could it be that power is the only reason why this AP is flapping (joining and unjoining) or something else as i have changed the country to GB as advised:
*Feb 15 03:29:46.663: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.1.2
*Feb 15 03:29:46.663: %DTLS-5-ALERT: Received WARNING : Close notify alert from 192.168.1.2
*Feb 15 03:29:46.663: %DTLS-5-PEER_DISCONNECT: Peer 192.168.1.2 has closed connection.
*Feb 15 03:29:46.663: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.1.2:5246
*Feb 15 03:29:46.707: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Feb 15 03:29:46.763: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Feb 15 03:29:46.783:  status of voice_diag_test from WLC is false
*Feb 15 03:30:02.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.1.2 peer_port: 5246
*Feb 15 03:30:02.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Feb 15 03:30:02.663: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 192.168.1.2 peer_port: 5246
*Feb 15 03:30:02.663: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.1.2
*Feb 15 03:30:02.663: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Feb 15 03:30:07.663: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.1.2
*Feb 15 03:30:07.663: %DTLS-5-ALERT: Received WARNING : Close notify alert from 192.168.1.2
*Feb 15 03:30:07.663: %DTLS-5-PEER_DISCONNECT: Peer 192.168.1.2 has closed connection.
*Feb 15 03:30:07.663: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.1.2:5246
*Feb 15 03:30:07.707: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Feb 15 03:30:07.763: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Feb 15 03:30:07.783:  status of voice_diag_test from WLC is false
*Feb 15 03:30:24.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.1.2 peer_port: 5246
*Feb 15 03:30:24.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Feb 15 03:30:24.659: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 192.168.1.2 peer_port: 5246
*Feb 15 03:30:24.659: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.1.2
*Feb 15 03:30:24.659: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
VIP Purple
did you check the box for "Accept Manufactured Installed certificate box" ?
If not then check it. otherwise AP will not join.
Guys, i have noticed that unlike before the AP has joined and remind join for atleast 5mins sine i checked the box
Accept Manufactured Installed certificate box.
The below is what i get now after i issue the below command:
(Cisco Controller) >show ap join stats detailed f029.29c2.efe0
Discovery phase statistics
- Discovery requests received.............................. 102
- Successful discovery responses sent...................... 90
- Unsuccessful discovery request processing................ 12
- Reason for last unsuccessful discovery attempt........... Discovery request decoding with subnet broadcast and wrong AP IP address
- Time at last successful discovery attempt................ Feb 15 03:38:44.958
- Time at last unsuccessful discovery attempt.............. Feb 15 03:15:53.737
Join phase statistics
- Join requests received................................... 147
- Successful join responses sent........................... 5
- Unsuccessful join request processing..................... 74
- Reason for last unsuccessful join attempt................ RADIUS authorization is pending for the AP
- Time at last successful join attempt..................... Feb 15 03:38:55.632
- Time at last unsuccessful join attempt................... Feb 15 03:38:55.634
Configuration phase statistics
- Configuration requests received.......................... 11
- Successful configuration responses sent.................. 1
- Unsuccessful configuration request processing............ 4
- Reason for last unsuccessful configuration attempt....... Regulatory domain check has failed for the AP
--More-- or (q)uit
- Time at last successful configuration attempt............ Feb 15 03:38:55.819
- Time at last unsuccessful configuration attempt.......... Feb 15 03:20:12.564
Last AP message decryption failure details
- Reason for last message decryption failure............... Not applicable
Last AP disconnect details
- Reason for last AP connection failure.................... Not applicable
- Last AP disconnect reason................................ AP's capwap state machine restarted
Last join error summary
- Type of error that occurred last......................... Lwapp join request rejected
- Reason for error that occurred last...................... RADIUS authorization is pending for the AP
- Time at which the last join error occurred............... Feb 15 03:38:55.634
Ethernet Mac : f0:29:29:c2:ef:e0  Ip Address : 192.168.1.8
That is the default setting on the WLC and shouldn't of been removed. Well at least you have it joined.
-Scott
VIP Purple
Glad that finally you got it. but just for info fro mesh AP.
There are only few things you must check.
1. MIC box is checked.
2. Mac address should be there in AP Policy.
3. Country code should be matched with your AP.(as per your info......it should be europe)
If you look at the data sheet for the 1550, that will list the power source that will be able to power up these MESH AP's
http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1550-series/data_sheet_c78-641373.html
If you have this in a lab, you can keep the 1550 connected to that switch, but you will not be able to test associations since the radios will be in a down state. Like Sandeep mentioned, make sure the country codes are correct. I would verify that the WLC time is correct and I would place the AP on the same subnet as the WLC for lab purposes. That is how I stage MESH AP's. If you still can't get the AP to join the WLC, then I would verify that the MAC address is correct, remove it and add it back.
-Scott
Guys,
Thanks for the assistance so far. I might have to wait till Monday (17/02/14) when i get the PoE power injector and power up the radios to know for sure if all we have done works correct and currently the AP is joined to the WLC.
Thanks once again.
Obinna Samuel
VIP Purple
Glad that works, yes power injector are always prefrred.
did you enabled :
Enable the 802.11 networks as follows:
  1. #Choose Wireless > 802.11a/n > Network.
  2. #select the 802.11a Network Status check box.
  3. #Click Apply.
  4. #Choose Wireless > 802.11a/n > Network.
  5. #select the 802.11b/g Network Status check box.
  6. #Click Apply.
Dont forget to rate helpful posts and mark this as answered, it may help others.
1103
