01-07-2014 12:44 AM - edited 07-04-2021 11:54 PM
Hi all, with the last release 7.4.110.x on WLC Cisco AP 1600 Support CleanAir Express technology ?
The documentation says that it will be supported in the future ... but when ??
Solved! Go to Solution.
03-05-2014 07:14 AM
I dont want to be shouted at so I will try and ask general question of this thread differently....
Leo,
You have said Express means things arent visible. I can accept some of that if its a cut down system, but there must be a way to check its on or doing something? If you cant prove its doing something its essentially a feature that you dont trust and wouldnt ever use surely? Also according to the recent 2014 at-a-glance guide: http://www.cisco.com/c/dam/en/us/solutions/collateral/borderless-networks/cleanair-technology/aag_c22-594304.pdf
it says:
"With Clean Air Express the Aironet 1600 Access Point has the ability to effectively detect RF interference, identify the source, locate it on a map..."
If its talking about a map, it must be hooking into Prime/NCS somewhere?
Leo and Scott Fella,
This doc also says that Express is planned for future support. The question here is, what is planned for future support exactly and when? I take this to mean that there is no Express functionality at all today until a future code version. Therefore how has anyone got anything working if its not available let alone prove it if there is no way of testing it?
This feels like a very wooly and grey subject area to me...
01-07-2014 12:51 AM
1600 supports CleanAir Express. This means that instead of a dedicated harware to do CleanAir work, the AP will use the CPU to do CleanAir.
01-07-2014 01:24 AM
in which firmware this feature was introduced ?
01-07-2014 01:33 AM
AP1600 was supported in WLC firmware 7.4.100.X.
01-07-2014 02:24 AM
Ap 1600 does not report interference, or air quality information.. ? why ?
if i select a radio a/bg-n the output show "cleanair capable NO" and "cleanair admin status disabled" was not configurable and reported in grey. Why if clean air was supported on that firmware ?
01-07-2014 02:38 AM
01-08-2014 03:21 AM
My configuration is correct. this is some print screen:
BUt i cant see the functionality.... Lao Have you ever configured that feature ? or you attach information from configuration guiude, You have real experience on that feature ?
this is my output and don't work !! with AP 1600.
That feature is supported or not on ap 1600 firmware 7.4.110 ??
01-08-2014 03:23 AM
CleanAir EXPRESS is supported only on the 1600.
This CleanAir EXPRESS means that the APs CPU will do all the work as well as NO REPORTS are forwarded to the WLC. If you want to see reports on the WLC then you need to use the 2600, 3500, 3600 and/or 3700.
Sent from Cisco Technical Support Wii App
01-08-2014 04:03 AM
Don't show interference
don't show air quality report
don't mitigate interference (change channel)
Leo have you tested this feature ? mitigate the interference ? For me don't work !!
01-08-2014 04:05 AM
I am telling you the SECOND time: CleanAir EXPRESS does not generate these reports you are looking for. This is what you get when you use CleanAir EXPRESS.
01-08-2014 05:30 AM
Ok not generate report for 1600.
Mitigate the interference this feature for 1600 ?
There is some output that demonstrates its functionality or debug command ?
I can not find anything about it .
01-08-2014 06:02 AM
I think you need to understand what's not available with CleanAir express. In this PDF, it shows you what CleanAir express does. Since this doesn't happen on the WLC, the AP does its mitigation automatically. No interferes will show up or be collected on the WLC. If you wanted to see the interferers, then you would have to purchase a 2600, 3600 or 3700.
01-15-2014 12:45 AM
Hi fella i don't find the PDF ? have you tested the functionality of mitigation ?
01-08-2014 01:43 PM
For the THIRD TIME: You WILL NOT BE ABLE to find any information, report and/or statistics about CleanAir when you are using AP1600.
This is because 1600 uses CleanAir Express.
If you want these informations, reports and/or statistics then you need to use either one of these models: 2600, 3500, 3600 3700. These models support CleanAir.
03-05-2014 07:14 AM
Leo,
it says:
