AP 1600 management interface issue
Hello
I have a strange issue with configuring management interface on my new AIR-SAP1602E-E-K9 Access Point. I'm trying to configure AP maangement interface in vlan 33. The problem is that I can only access AP when vlan 33 is configured as untagged on switch port where AP is connected. As you can see in my config, management interface is configured in bvi100 which is bridged to subinterface gi0.33 (encapsulated to vlan 33) and should not work in native vlan.
AP#sh run
Building configuration...
Current configuration : 1826 bytes
! Last configuration change at 00:50:36 UTC Mon Mar 1 1993
version 15.2
no service pad
service password-encryption
hostname AP
logging rate-limit console 9
no aaa new-model
ip cef
ip domain name temp.com
dot11 syslog
username przemek privilege 15 secret 5 $1$j
ip ssh version 2
bridge irb
interface Dot11Radio0
no ip address
shutdown
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
no ip address
shutdown
antenna gain 0
no dfs band block
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
no ip address
duplex auto
speed auto
bridge-group 1
interface GigabitEthernet0.33
encapsulation dot1Q 33
bridge-group 100
bridge-group 100 spanning-disabled
no bridge-group 100 source-learning
interface BVI1
no ip address
shutdown
interface BVI100
ip address 192.168.10.201 255.255.255.0
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip route 0.0.0.0 0.0.0.0 192.168.10.1
bridge 1 route ip
bridge 100 route ip
line con 0
line vty 0 4
login local
transport input all
end
I found another thing:
AP-BIURO#sh vlans
Virtual LAN ID:  1 (IEEE 802.1Q Encapsulation)
   vLAN Trunk Interface:   GigabitEthernet0
This is configured as native Vlan for the following interface(s) :
GigabitEthernet0
   Protocols Configured:   Address:              Received:        Transmitted:
        Bridging        Bridge Group 1                  0                   0
        Other                                           0                 404
   0 packets, 0 bytes input
   404 packets, 31608 bytes output
Virtual LAN ID:  33 (IEEE 802.1Q Encapsulation)
   vLAN Trunk Interface:   GigabitEthernet0.33
        Bridging        Bridge Group 100               56                   0
   112 packets, 10192 bytes input
   0 packets, 0 bytes output
It looks like all packets coming in on tagged interface (vlan 33) and going back through native vlan. Is it some bug or am I doing something wrong?
Thanks.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: AP 1600 management interface issue
The default requirement for any autonomous access point is that management has to be untagged. You will not be able to tag the management vlan.
-Scott
-Scott
Right. I agree with Scott.
Management must be untagged.
Rating useful replies is more useful than saying "Thank you"
Thank for the answer. Of course it's working on untagged interface. I thought that this if a bug, but not a feature.
Do you know the reason why Cisco haven't implemented management interface  on tagged port?
361
