AP 2600 problem
IOS Bootloader - Starting system.
flash is writable
FLASH CHIP:  Numonyx Mirrorbit (0089)
Xmodem file system is available.
flashfs[0]: 39 files, 9 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 31997952
flashfs[0]: Bytes used: 18512896
flashfs[0]: Bytes available: 13485056
flashfs[0]: flashfs fsck took 17 seconds.
Reading cookie from SEEPROM
Base Ethernet MAC address: 7c:ad:74:db:52:37
Ethernet speed is 100 Mb - FULL Duplex
Loading "flash"...flash: permission denied
Error loading "flash"
Interrupt within 5 seconds to abort boot process.
Loading "/ap3g2-k9w8-mx.152-2.JB".../ap3g2-k9w8-mx.152-2.JB: permission denied
Error loading "/ap3g2-k9w8-mx.152-2.JB"
Loading "flash:/ap3g2-k9w8-mx.152-2.JB/ap3g2-k9w8-xx.152-2.JB"...uncompress: Unknown mzip segment type: 2
Error loading "flash:/ap3g2-k9w8-mx.152-2.JB/ap3g2-k9w8-xx.152-2.JB"
Boot process failed...
The system is unable to boot automatically.  The BOOT
environment variable needs to be set to a bootable
image.
C2600 Boot Loader (AP3G2-BOOT-M) LoaderVersion 12.4(25e)JA1, RELEASE SOFTWARE (fc1)
Compiled Wed 30-May-12 03:34 by binugopa
ap:
ap:
ap:
Hall of Fame Super Silver
AP 2600 problem
You need to upload new code:
https://supportforums.cisco.com/thread/2043235
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
VIP Purple
AP 2600 problem
HI Walid,
Try this method:
Make sure the AP has network-connectivity to an TFTP-server (Example Tftp is at ip, 10.10.10.10). Then issue the following commands;
ap: set IP_ADDR 10.10.10.20
ap: set NETMASK 255.255.255.0
ap: set DEFAULT_ROUTER 10.10.10.1
ap: tftp_init
Then we delete the current IOS (.tar). We are now ready to copy the new IOS (and properly this time). Issue the following command;
ap: delete flash:
Are you sure you want to delete "flash:r" (y/n)?y
File "flash:r" deleted
ap: tar -xtract tftp://10.10.10.10/flash:
Then boot the newly extracted IOS;
ap: boot
Loading "flash:"...flash:: no such file or directory
Error loading "flash:"
Loading "flash://"...############
File "flash://" uncompressed and installed, entry point: 0x4000
Please also check this dcoument:
https://supportforums.cisco.com/docs/DOC-14636
261
