Community Member
AP 350 Series Routing
Is there a way to use the wireless signal obtained by the access point (in this case a repeater) and route it to a wired network or the ethernet port on the access point itself? I know there is a routing option under "Services" on the Access Point but I wanted to make sure this was possible before I made any configurations.
Thank you,
David
kil.5@nd.edu
1 REPLY
Re: AP 350 Series Routing
In case of access point acting as a "Repeater" ethernet port of that "Repeater" will be disabled..So You can't communicate with the wired LAN on Repeater over the wireless link.
256
