Community Member
AP 3500 freeze bright white light
I have problem with this 2 AP model 3500i out of 140 APs. below is my finding:-
1. Suspected AP froze with bright white light and dissociated from controller
2. After bounce back (shut / no shut) the port, its working as normal
3. In a while, its repeat to (1.)
4. Direct console to the AP, no output is seen.
From NCS & controller log, its only show as below:
AP 'TTR13-A03AP0076' disassociated from Controller '10.209.116.16'
AP 'TTR4-A02AP0014' disassociated from Controller '10.209.116.15'
Is there anyone having the same issues?
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: AP 3500 freeze bright white light
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtu24972
-Scott
There is a thread I will try to find, but opening a TAC case is what you probably should do. They can walk you throught the fix, or just RMA.
-Scott
-Scott
Search the forum for this thread:
issues with 3500i AP's LED glowing bright white
-Scott
Community Member
Thanks Fella. This might help.
No problem
-Scott
1713
