AP 3602I won't load
Hello we have a 5508 controller and mulitiple 3602I APs. One of our APs stopped working. Connected to the console port I can see that the loading process hangs. I formated flash, ran fsck and extracted the latest tar file but I have the same result.
"Loading "flash:/ap3g2-k9w8-mx.152-4.JB6/ap3g2-k9w8-xx.152-4.JB6"..." and the LED is off. What else should I try? tks
ap: set
BOOT=flash:/ap3g2-k9w8-mx.152-4.JB6/ap3g2-k9w8-mx.152-4.JB6
DEFAULT_ROUTER=10.0.0.1
IP_ADDR=10.0.0.1
NETMASK=255.255.255.224
ap: dir flash:
Directory of flash:/
3    -rwx  286       <date>               info
4    drwx  1984      <date>               ap3g2-k9w8-mx.152-4.JB6
57   -rwx  125       <date>               env_vars
18242560 bytes available (13755392 bytes used)
ap: boot
Rebooting system to reset DPAA...
IOS Bootloader - Starting system.
flash is writable
FLASH CHIP:  Spansion Mirrorbit (0001)
Xmodem file system is available.
flashfs[0]: 49 files, 7 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 31997952
flashfs[0]: Bytes used: 13755392
flashfs[0]: Bytes available: 18242560
flashfs[0]: flashfs fsck took 15 seconds.
Reading cookie from SEEPROM
Base Ethernet MAC address: c4:64:13:c0:9f:69
Ethernet speed is 1000 Mb - FULL Duplex
Loading "flash:/ap3g2-k9w8-mx.152-4.JB6/ap3g2-k9w8-mx.152-4.JB6"...#########################
File "flash:/ap3g2-k9w8-mx.152-4.JB6/ap3g2-k9w8-mx.152-4.JB6" uncompressed and installed, entry point: 0x2003000
executing...
Secondary Bootloader - Starting system.
Tide MB - 32MB of flash
flashfs[0]: flashfs fsck took 8 seconds.
Boot CMD: 'boot  flash:/ap3g2-k9w8-mx.152-4.JB6/ap3g2-k9w8-xx.152-4.JB6;flash:/ap3g2-k9w8-mx.152-4.JB6/ap3g2-k9w8-mx.152-4.JB6'
Loading "flash:/ap3g2-k9w8-mx.152-4.JB6/ap3g2-k9w8-xx.152-4.JB6"... the file never actually loads.
Hall of Fame Super Gold
That filename is a full
That filename is a full controller-based IOS.  What happens in you try to load an "RCV" file?
I let it sit over night with
I let it sit over night with the same result but with a different twist. The OS still won't load but the LED light is green.
flash is writable
flash is writable
Mode button pressed.
Mode button held for at least 20 seconds.
process_config_recovery: set IP address and config to default 10.0.0.1
process_config_recovery: image recovery
image_recovery: Download default IOS tar image tftp://255.255.255.255/ap3g2-k9w7        -tar.default
examining image...
DPAA Set for Independent Mode
DPAA_INIT = 0x0
%Error opening tftp://255.255.255.255/ap3g2-k9w7-tar.default (connection timed o        ut)ap:
ap:
ap:
ap:
ap:
ap: format flash:
Are you sure you want to format "flash:" (all data will be lost) (y/n)?y
flashfs[0]: 0 files, 1 directories
flashfs[0]: Bytes used: 1024
flashfs[0]: Bytes available: 31996928
flashfs[0]: flashfs fsck took 32 seconds.
Filesystem "flash:" formatted
ap:
ap:
ap:
ap:
ap: ether_init
Initializing ethernet port 0...
ap: tftp_init
ap: flash_init
Initializing Flash...
...The flash is already initialized.
ap:
ap:
ap: set IP_ADDR 172.16.19.100
ap: set NETMASK 255.255.248.0
ap: set DEFAULT_ROUTER 172.16.16.1
ap: tar -xtract tftp://172.16.16.76/wlc/ap3g2-rcvk9w8-tar.152-4.JB6.tar flash:
extracting info (264 bytes)
ap3g2-rcvk9w8-mx/ (directory) 0 (bytes)
extracting ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-mx (208427 bytes).....................        ........................
extracting ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-tx (73 bytes)
extracting ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx (7141872 bytes)....................        ................................................................................        ................................................................................        ................................................................................        ................................................................................        ................................................................................        ................................................................................        ................................................................................        ................................................................................        ................................................................................        ................................................................................        ................................................................................        ................................................................................        ................................................................................        ................................................................................        ................................................................................        ................................................................................        ................................................................................        ................................................................................        ................................................................................        .........
extracting ap3g2-rcvk9w8-mx/info (264 bytes)
extracting ap3g2-rcvk9w8-mx/file_hashes (572 bytes)
extracting ap3g2-rcvk9w8-mx/final_hash (141 bytes)
extracting ap3g2-rcvk9w8-mx/img_sign_rel.cert (1375 bytes)
extracting ap3g2-rcvk9w8-mx/img_sign_rel_sha2.cert (1371 bytes)
extracting info.ver (264 bytes)ap:
ap:
ap:
ap:
ap: dir
List of filesystems currently registered:
               flash[0]: (read-write)
              xmodem[1]: (read-only)
                null[2]: (read-write)
                tftp[5]: (read-only)
ap: dir flash:
2    -rwx  71        <date>               env_vars
3    -rwx  264       <date>               info
4    drwx  512       <date>               ap3g2-rcvk9w8-mx
13   -rwx  264       <date>               info.ver
24638464 bytes available (7359488 bytes used)
ap: dir flash:/ap3g2-rcvk9w8-mx
Directory of flash:/ap3g2-rcvk9w8-mx/
5    -rwx  208427    <date>               ap3g2-rcvk9w8-mx
6    -rwx  73        <date>               ap3g2-rcvk9w8-tx
7    -rwx  7141872   <date>               ap3g2-rcvk9w8-xx
8    -rwx  264       <date>               info
9    -rwx  572       <date>               file_hashes
10   -rwx  141       <date>               final_hash
11   -rwx  1375      <date>               img_sign_rel.cert
12   -rwx  1371      <date>               img_sign_rel_sha2.cert
ap: boot
flash is writable
flashfs[0]: 11 files, 2 directories
flashfs[0]: Bytes used: 7359488
flashfs[0]: Bytes available: 24638464
flashfs[0]: flashfs fsck took 13 seconds.
Loading "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-mx"...#########################
File "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-mx" uncompressed and installed, entr        y point: 0x2003000
executing...
flashfs[0]: flashfs fsck took 7 seconds.
Boot CMD: 'boot  flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx'
Loading "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx"... NOT loading
Ok, the IOS is corrupt.   One
One of the easiest solution is to load the autonomous IOS using the Mode button method.  Once the AP boots into autonomous, copy the RCV file back.
Before you copy the RCV file back, make sure you compare the MD5 hash value against the value found in the Cisco website.  They need to match.
Hello Leo, I think that is
Hello Leo, I think that is the process I'm already using. Here is the process I'm using to copy a different Software.
I hold the mode button for a least 20 seconds until I get to the ap: prompt.
I format flash:
ether_init
tftp_init
flash_init
I configure IP, SM, DG
I verified the hash and it matches. also flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx" was extracted from the tar file so i doubt it would be corrupted.
The only thing that make sense is RAM is defective. I'm assuming "Loading" means loading into memory.
Thank you
Read this:  Using a TFTP
Hello Leo, if I understand
Hello Leo, if I understand correctly you want me to boot the AP from my tftp server using an Autonomous version of the software and then convert it to lightweight. I guess I will have to contact Cisco because I can't download the autonomous software. I have the message that I need additional entitlement to download it :-(. I don't have that message on the lightweight software.
Looks like I’m in a catch 22.
Looks like I’m in a catch 22. TFTP only works if I issue the command ether_init but I can’t do that in recovery mode or can I? is there a way to call a recovery image from the command line?
463
