AP AIR-CAP1602I-C-K9 Not Join with WLC 2500
Please this is my Problem , I can access to WLC fine no problem , But with i connected the AP 16021 to the POE from WLC , This Syslog comes in as attached . Thank You in Advince .
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: BC:16:65:06:E0:03
Part Number                          : 73-14671-04
PCA Assembly Number                  : 000-00000-00
PCA Revision Number                  :
PCB Serial Number                    : FOC17014029
Top Assembly Part Number             : 800-38552-01
Top Assembly Serial Number           : FGL1723W8D0
Top Revision Number                  : A0
Product/Model Number                 : AIR-CAP1602I-C-K9
*Mar  1 00:01:59.866: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'WLC'runn
ing version 7.2.103.0 is rejected.
*Mar  1 00:01:59.866: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:01:59.866: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process m
essage type 2 state 2.
*Mar  1 00:01:59.866: %CAPWAP-3-ERRORLOG: Failed to handle capwap control messag
e from controller
*Mar  1 00:01:59.866: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap p
acket from 192.168.10.1
*Mar  1 00:02:18.866: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'WLC'runn
*Mar  1 00:02:18.866: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:02:18.866: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process m
*Mar  1 00:02:18.866: %CAPWAP-3-ERRORLOG: Failed to handle capwap control messag
e from controller
*Mar  1 00:02:18.866: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap p
e from controller
  • Getting Started with Wireless
4 ACCEPTED SOLUTIONS
VIP Purple
Re: AP AIR-CAP1602I-C-K9 Not Join with WLC 2500
The first IOS support by 1602 AP is 7.4.100.0.
You must upgrade the software on wlc to minimum 7.4.100.0.
Chek mtrix compatibilty: http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html
Dont forget to rate helpful posts.
VIP Purple
you have wrong regulatery domain on Access point:
AIR-CAP1602I-C-K9
Your wlc is set to US.
Change the country on wlc and then try again.
which country u r in ?????
VIP Purple
How to change  country on WLC:
By CLI
Before you can change the country code of a WLC, you must disable the 802.11a and 802.11b network :
config 802.11a disable network
config 802.11b disable network
Now you can change the country code of the controller. In this case we change it from US to MY (Malaisya)
config country MY
thenable againthe both networks
config 802.11a enable network
config 802.11b enable network
By GUI:
First disable both network 802.11a and 802.11b
Follow these steps to disable the 802.11a and 802.11b/g networks as follows:
  •     Choose Wireless> 802.11a/n > Network.
  •     Unselect the 802.11a Network Status check box.
  •     Click Apply to commit your changes.
  •     Choose Wireless > 802.11b/g/n > Network.
  •     Unselect the 802.11b/g Network Status check box.
Change country code on WLC now:
Choose Wireless > Country
VIP Purple
Left side click on 802.11b/g/n.....oper status should be UP.
Reagrds
Dont forget to rate helpful posts, also mark this question as answered
VIP Purple
Thank You Sand For your Reply , I Already update to (
air-ct2500-k9-7-4-110-0.aes )
And at the ferist Time The WLC an See the AP but after few Second the AP no more to the WLC
And give me the Syslog beloow . Any Idea ,  appricated your great help
*Jan  8 04:34:12.487: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process m
essage type 10 state 5.
*Jan  8 04:34:12.487: %CAPWAP-3-ERRORLOG: Failed to handle capwap control messag
e from controller
*Jan  8 04:34:12.487: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap pac
VIP Purple
power off the AP and put the whole boot process here.
all logs......paste here :
also paste:
wlc: sh sysinfo
AP:sh inventory
regards
After Power Off and ON
Press RETURN to get started!
*Mar  1 00:00:12.007: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self t
est passed
*Mar  1 00:00:14.431: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self
test passed on interface Dot11Radio 0
*Mar  1 00:00:14.555: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state
to up
*Mar  1 00:00:15.543: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self
test passed on interface Dot11Radio 1
*Mar  1 00:00:18.303: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C1600 Software (AP1G2-K9W8-M), Version 15.2(2)JB2, RELEASE S
OFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Mon 29-Jul-13 12:35 by prod_rel_team
*Mar  1 00:00:18.303: %SNMP-5-COLDSTART: SNMP agent on host APbc16.6506.e003 is
undergoing a cold start
*Mar  1 00:00:18.339: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to r
eset
*Mar  1 00:00:18.339: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to r
eset
*Mar  1 00:00:18.847: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEth
ernet0, changed state to up
*Mar  1 00:00:19.463: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, chan
ged state to up
*Mar  1 00:00:21.719: %SSH-5-ENABLED: SSH 2.0 has been enabledlwapp_crypto_init:
MIC Present and Parsed Successfully
%Default route without gateway, if not a point-to-point interface, may impact pe
rformance
*Mar  1 00:00:40.903: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power s
ource
*Mar  1 00:00:41.967: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:00:42.967: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
*Mar  1 00:00:43.023: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:00:44.023: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
*Mar  1 00:00:47.103: Logging LWAPP message to 255.255.255.255.
*Mar  1 00:00:54.647: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP addre
ss 192.168.10.2, mask 255.255.255.0, hostname APbc16.6506.e003
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (192.168.10.10)
*Mar  1 00:01:10.519: %CAPWAP-3-ERRORLOG: Did not get log server settings from D
HCP.
*Mar  1 00:01:19.519: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROL
LER
*Mar  1 00:01:29.519: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jan  8 04:49:53.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
p: 192.168.10.1 peer_port: 5246
*Jan  8 04:49:55.483: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
peer_ip: 192.168.10.1 peer_port: 5246
*Jan  8 04:49:55.483: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.10.1
*Jan  8 04:49:55.483: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination
*Jan  8 04:49:55.483: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process m
*Jan  8 04:49:55.483: %CAPWAP-3-ERRORLOG: Failed to handle capwap control messag
e from controller
*Jan  8 04:49:55.483: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap pac
*Jan  8 04:50:13.607: %CAPWAP-3-ERRORLOG: Retransmission count for packet exceed
., 1)x(UNKNOWN_MESSAGE_TYPE (5)
*Jan  8 04:50:13.607: %CAPWAP-3-ERRORLOG: GOING BACK TO DISCOVER MODE
*Jan  8 04:50:13.607: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192
.168.10.1:5246
*Jan  8 04:50:13.655: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led sta
te 255
*Jan  8 04:50:13.671: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to a
dministratively down
*Jan  8 04:50:13.671: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to a
*Jan  8 04:50:13.687: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Jan  8 04:50:13.727: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Jan  8 04:50:14.671: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
0, changed state to down
*Jan  8 04:50:14.723: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to do
wn
*Jan  8 04:50:14.731: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to r
eset
*Jan  8 04:50:15.715: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
*Jan  8 04:50:15.723: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
1, changed state to down
*Jan  8 04:50:15.767: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Jan  8 04:50:15.775: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to do
wn
*Jan  8 04:50:15.783: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to r
eset
*Jan  8 04:50:16.767: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
*Jan  8 04:50:16.775: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
*Jan  8 04:50:16.811: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Jan  8 04:50:17.811: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
*Jan  8 04:50:29.723: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jan  8 04:50:30.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
*Jan  8 04:50:30.487: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
*Jan  8 04:50:30.487: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.10.1
*Jan  8 04:50:30.491: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination
*Jan  8 04:50:30.491: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process m
*Jan  8 04:50:30.491: %CAPWAP-3-ERRORLOG: Failed to handle capwap control messag
e from controller
*Jan  8 04:50:30.491: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap pac
*Jan  8 04:50:48.919: %CAPWAP-3-ERRORLOG: Retransmission count for packet exceed
*Jan  8 04:50:48.919: %CAPWAP-3-ERRORLOG: GOING BACK TO DISCOVER MODE
*Jan  8 04:50:48.919: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192
.168.10.1:5246
*Jan  8 04:50:48.963: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led sta
te 255
*Jan  8 04:50:48.983: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to a
*Jan  8 04:50:48.983: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to a
*Jan  8 04:50:48.995: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Jan  8 04:50:49.027: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Jan  8 04:50:49.983: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
*Jan  8 04:50:50.031: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to do
wn
*Jan  8 04:50:50.039: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to r
eset
*Jan  8 04:50:51.023: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
*Jan  8 04:50:51.031: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
*Jan  8 04:50:51.075: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Jan  8 04:50:51.083: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to do
wn
*Jan  8 04:50:51.091: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to r
eset
*Jan  8 04:50:52.075: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
*Jan  8 04:50:52.083: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
*Jan  8 04:50:52.119: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Jan  8 04:50:53.119: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
*Jan  8 04:51:05.027: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jan  8 04:51:05.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
*Jan  8 04:51:05.487: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
*Jan  8 04:51:05.487: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.10.1
*Jan  8 04:51:05.487: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination
*Jan  8 04:51:05.487: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process m
*Jan  8 04:51:05.487: %CAPWAP-3-ERRORLOG: Failed to handle capwap control messag
e from controller
*Jan  8 04:51:05.487: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap pac
APbc16.6506.e003#sh inventory
NAME: "AP1600", DESCR: "Cisco Aironet 1600 Series (IEEE 802.11n) Access Point"
PID: AIR-CAP1602I-C-K9 , VID: V01, SN: FGL1723W8D0
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.4.110.0
Bootloader Version............................... 1.0.16
Field Recovery Image Version..................... 1.0.0
Firmware Version................................. PIC 16.0
Build Type....................................... DATA + WPS
System Name...................................... WLC
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 192.168.10.1
Last Reset....................................... Software reset
System Up Time................................... 0 days 3 hrs 12 mins 37 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
--More-- or (q)uit
Configured Country............................... US  - United States
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +36 C
External Temperature............................. +41 C
Fan Status....................................... 4200 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
Memory Current Usage............................. Unknown
Memory Average Usage............................. Unknown
CPU Current Usage................................ Unknown
CPU Average Usage................................ Unknown
Burned-in MAC Address............................ 50:06:04:CB:C2:40
Maximum number of APs supported.................. 5
VIP Purple
AIR-CAP1602I-C-K9
Hall of Fame Super Gold
Please post the output to the command "sh sysinfo".
Sent from Cisco Technical Support Wii App
So I live in Malaysia , probably I selected or I have to select specific country ?
Thank you in advance :)
705
