Community Member
AP and DHCP problem
I have a router with 2 subinterfaces.
interface GigabitEthernet0/0.1
encapsulation dot1Q 20 native
ip address 130.130.130.1 255.255.255.0
ip helper-address 192.168.1.5
interface GigabitEthernet0/0.99
encapsulation dot1Q 99
ip address 120.120.120.43 255.255.255.248
I have a 3750 level 2 with this vlans.
interface Vlan99
ip address 120.120.120.41 255.255.255.248
interface Vlan20
ip address 130.130.130.10 255.255.255.0
I have the AP is connected to a port in the 3750
interface FastEthernet1/0/47
switchport trunk native vlan 99
switchport trunk allowed vlan 20,99
switchport mode trunk
Users connected to the 3750 ports vlan 20 can get IP from the range 130.xx
I want users connected to the access point to have IP's from range vlan20 (130.xx) (the same that the users connected to the 3750)
HOw can i do it?
Re: AP and DHCP problem
AP Config will basically look like this...
dot11 ssid mywifi
vlan 20
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 20 <>
ssid mywifi
short-slot-time
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2437
station-role root access
interface Dot11Radio0.99
encapsulation dot1Q 99 native
no ip route-cache
bridge-group 1
bridge-group 1 spanning-disabled
interface Dot11Radio0.20
no ip route-cache
bridge-group 20
bridge-group 20 subscriber-loop-control
bridge-group 20 block-unknown-source
no bridge-group 20 source-learning
no bridge-group 20 unicast-flooding
bridge-group 20 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.99
no ip route-cache
bridge-group 1
no bridge-group 1 source-learning
interface FastEthernet0.20
no ip route-cache
bridge-group 20
interface BVI1
ip address <>
no ip route-cache
ip default-gateway <>
Community Member
I think something is wrong in the switch config because users that connect to the AP can not get an IP..
From the little that's there, the switch config looks fine.
247
