AP disassociated from WLC 2504
Zohaib Khan
I have facing a problem when i try to add my AP to WLC 2504 after downloading frimeware AP disassociate from WLC and i can't access it any more even not shown in WLC GUI as well
I check the log error is
"AP Disassociated. Base Radio MAC:xx:xx:xx:xx:xx:xx"
WLC is 2504 WLC with 7.5...IOS
AP model Air cap3602i-a-k9
If some one has solution please reply ASAP
Thank you
13 Replies 13
Zohaib Khan
Complete details about WLC 2504 are
Product Version........................ 7.5.102.0
Bootloader Version............................... 1.0.18
Field Recovery Image Version..................... 1.0.0
Firmware Version................................. PIC 16.0
Hi zohaib,
this can happen if you have multiple controller, AP might get confused to which should it take on priority. Rebooting the AP can resolve the problem
OR
Set the primary and secondary controller
Dear Salman,
Thanks for you response but i am using only one controller, so in my scenario your answer cant help me.
still looking for solution
Console into the AP and post the "sh logs".  There's a possibility the WLC's time synch is lost and the AP won't join because the WLC has incorrect time and date settings.
AP download frimewareand all setting from WLC how date and time can be incorrect
Post the following output:
1.  WLC:  sh sysinfo;
2.  WLC:  sh time
3.  AP:  sh version;
4.  AP:  sh ip interface brief; and
5.  AP:  sh inventory
Dear Leo,
Sorry for late reply but question is how i can give these commands to AP
3.  AP:  sh version;
5.  AP:  sh inventory
I can't able to access AP user mode from console when i attached console its keeps giving me log which i already mention below nothing elso. no user mode or any thing ....i think its is because AP downloaded frimeware from WLC and upgraded itself and now it keep searching WLC
Logs at AP:
*Nov 17 03:15:05.000: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Nov 17 03:15:05.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: x.x.x.x peer_port: 5246
*Nov 17 03:15:05.411: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: x.x.x.x peer_port: 5246
*Nov 17 03:15:05.411: %CAPWAP-5-SENDJOIN: sending Join Request to x.x.x.x
*Nov 17 03:15:05.415: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination.
*Nov 17 03:15:05.415: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 10 state 5.
*Nov 17 03:15:05.415: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Nov 17 03:15:05.415: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap packet from x.x.x.x
Press the key and you'll interrupt the logging console.
Already done that didnt work in my case
Hi Zohaib,
same issue which you are facing is resolved in below link
https://supportforums.cisco.com/message/1276617#1276617
Salman Abid
i checked this log on AP
Also check the time its configured and correct
I check list of regulatory list for my WLC AP CAP3602  is mention for my regulatory doamin ..i tried to manual add AP and i check it  joined status i found this error
you can see there is domain check fail what should i do now?
Issue Successfully identified
My AP:  Product/Model Number    : AIR-CAP3602E-N-K9.
As per my Country(United Arab Emirat) it should be : AIR-CAP3602E-E-K9
So now contact supplier and tell him to change the AP with right regulatery domain.
Problem is  with regulatery domain
