04-15-2010 09:37 AM - edited 07-03-2021 06:44 PM
Hi Guys,
Good day!
I will be installing a 2x Wireless AP (1242-AG) in 60m square room, I will install it in both ends of the room. My question is what are the guidelines that I will be considering in situation like this, e.g. channels to be used, % overlaps (to avoid disconnection when user pass to other access point), antennae... etc.
Thanks in advance!
regards,
Gagamboy
Solved! Go to Solution.
04-15-2010 08:41 PM
do you mean I do not need to manualy adjust the channel of Wireless AP?
You should be able to get things working without making any adjustment to the channel assignments.04-15-2010 03:28 PM
Why? Do you want wireless coverage OUTSIDE the room too?
channels to be used
You should be fine. You have two APs so they'll automatically sort themselves out.04-15-2010 08:17 PM
Hi Leo,
Thanks for your feedback.
It will only serve inside the room, no need for outside. :-)
As for the channels, do you mean I do not need to manualy adjust the channel of Wireless AP?
Thanks in advance!
regards,
Mark
04-15-2010 08:41 PM
You should be able to get things working without making any adjustment to the channel assignments.04-15-2010 08:45 PM
Thanks Leo!
04-15-2010 09:02 PM
Thanks for the ratings.
