You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
AP interface Dot11Radio1 keeps flipping
I have 10 Cisco 1140 APs, all configed on one 5505 controller.  And I just found all those APs keep getting below logs
*Mar  2 03:12:23.467: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to down
*Mar  2 03:12:23.489: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  2 03:15:24.808: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to down
*Mar  2 03:15:24.830: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  2 03:18:25.236: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to down
*Mar  2 03:18:25.257: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  2 03:21:26.090: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to down
*Mar  2 03:21:26.112: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  2 03:24:27.802: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to down
*Mar  2 03:24:27.823: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
All those APs have two Radio interfaces, setup by default, Radio 0 is 802.11b/g/n, and Radio 1 .11a/n.
what is this? should I disable Radio interface 1?
Big Thank.
  • Getting Started with Wireless
Hall of Fame Super Silver
Re: AP interface Dot11Radio1 keeps flipping
Is there anything else you see in the logs besides this?
Thanks, Scott *****Help out other by using the rating system and marking answered questions as "Answered"*****
nothing else outstanding.
This can be DFS shutting down the radio, but you would see radar in the log. Here is a link of DFS.
https://supportforums.cisco.com/docs/DOC-13661
VIP Purple
I suspect, you may have a faulty radio.
But all my ten 1140 APs have the same problem.
Well if your seeing this and your not hitting DFS then open a RAC case so they can further investigate.
'hitting DFS'?  did you mean the DFS event?
this is the DFS events on one of my 1142s. Its radio if 1 is flipping as well.
DFS Statistics:
Radar Detected:         1
Inactive Radar Detected:0
RSSI Threshold Reached: 0
PW Threshold Reached:   0
PRI Threshold Reached:  0
Event Count:            1651
Chirp Count:            4
Max PRI Count:          3
Max Used PRI Bins:      4
Excess PRI Bins:        0
Should I just simple shut down Radio 1 on all my APs?
Hall of Fame Super Gold
Can you plase post the output to the command "sh interface dot111"?
Also, please post the output to the command "dir".
I agree with Sandeep, with the radio bouncing every three minutes could point to a bad radio.
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
207
