AP local power command
lcaruso
Level 6
Level 6
I would like to reduce the output signal from a group of APs connected to a 2504 controller. Is there a way to do this from the controller, or would I used the local power command on each AP to accomplish this or is there another way to get this done?
Thanks.
Amjad Abdullah
You can do that from WLC GUI:
Wireless -> Access Point -> Radios -> 802.11a/n (or b/g/n).
Hold the mouse over the blue square on the right of the AP and from the sub-menu that appears press (configure).
From there you can change the power and/or the channel.
Rating useful replies is more useful than saying "Thank you"
Amjad Abdullah
Abhishek Abhishek
Hello ,
As per your query I can suggest you the following solution –
You need to go as Wireless -> Access Point -> Radios -> 802.11a/n (or b/g/n).Then you can use the local power command on each AP to accomplish this.
Hope this will help you
