AP LWAPP with 2 SSID and 2 DHCP Differents
Hi everyone
I have a question
I need raise a especial configuration to 34 APs LWAPP associated to WLC 5508 with IOS 7.0.220
This is the Scenario:
We have 34 APs LWAPP with 2 SSID (Corporative & Guest), with 2 DHCP different. The Guest SSID receive IP to DHCP from WLC while SSID Corporative receive IP from Microsoft DHCP. The AP On Site are Local and the Foreign AP are configured like H-REAP (H-REAP Local switching and Learn Client IP Address are marked)
Here is the thing, I need configure a new WLAN (Pruebas) for add to 34 APs (Local and Foreign) but this new WLAN must be receive IP from a New Microsoft DHCP
Firstly I configured a new Physical interface and linked to New WLAN (Pruebas) however i don't know how configure the AP and the DHCP because I want that the AP deliver IP addresses depending the Locality.
The last because the SuperScope from DHCP is divided in various subnets and because the IP from the AP will be in another VLAN
Any idea?
thanks
Everyone's tags (5)
1 ACCEPTED SOLUTION
DHCP broadcast for locally switched wireless clients will be bridged at the local switch where AP is connected, as along as dhcp server is at that vlan or at L3 accessible via ip-helper is fine.
So on the remote site switches(where the APs got the ssid - Pruebas), you need to configure ip-helper on the respective interface/vlan to reach the msoft dhcp server.
You can create AP groups and map different locations to different interfaces. Different interfaces can be configured for different subnets and different DHCP servers.
Here is a config exmaple:  http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008073c723.shtml
Amjad
Rating useful replies is more useful than saying "Thank you"
Re: AP LWAPP with 2 SSID and 2 DHCP Differents
Hi guys
Thanks for the help
I configure the port where is connected the AP in Trunk, and tagged the VLAN like Native to VLAN where is the IP Administration to AP
switchport trunk native vlan X
switchport mode trunk
And in the New Interface VLAN (where link the new SSID) I configured the ip-helper to the DHCP,
interface vlan X
ip address 192.168.185.1 255.255.255.0
ip helper-address X.X.X.X
all this for the Switching & Routing Part, because in the Wireless Part, I just configure the AP in H-REAP and in VLAN Mapping configure the SSID Pruebas with VLAN ID (the same VLAN in Switch)
Thanks a lot for you support
I wrote the commands for someone with the same problem
784
