Showing results forĀ
Search instead forĀ
Did you mean:Ā
AP not able join to WLC
ittechk4u
One of the AP is not joing to 2504WLC.
AP Model:
CAP-3602I-E-K9
The error shows like this "Radius Authorization of the AP has failed"
What Could be the reason?
I check the regulatery domain, country code and compatibilty software but still I am not able to find the root cause.
Any Help will be appreciated.
3 Accepted Solutions
Sandeep Choudhary
Make sure to check/uncheck AP policies box on WLC.
From WLC GUI > Secuirty > AAA > AP policies, can you verify you have not checked "Authorize MIC APs against auth-list or AAA" ? If checked, uncheck this and try.
On the logs ": RADIUS authorization is pending for the AP  " means that this needs the MAC addr to be in the mac filter or AP Policies.
So, from WLC GUI>>Secuirty>>AAA>AP policies>>Add> ? (AP mac addr) and check if it joins.
Dont forget to arte helpful posts.
If u resolved your issue then can you marks this question as answered, it may help others.
Dont forget to rate helpful posts
6 Replies 6
Sandeep Choudhary
Thanks for reply.
Let me check it.
Bravo
Perfect Answer sandeep.
Thanks again for such a quick help.
Problem Resolved.
follow these steps to join outdoor AP
