AP not joining WLC 2504
Hi all
my customer has a 2504 WLC, and has problems to join APs (There are no aps joined to the controller at this moment).
What are the Bold lines tell me?
in the debug I see the following:
*spamApTask0: Oct 10 09:20:06.019: 58:f3:9c:78:d1:10 Discovery Request from 10.37.24.116:41508
*spamApTask0: Oct 10 09:20:06.019: 58:f3:9c:78:d1:10 ApModel: AIR-CAP3702I-N-K9
*spamApTask0: Oct 10 09:20:06.019: 58:f3:9c:78:d1:10 Join Priority Processing status = 0, Incoming Ap's Priority 4, MaxLrads = 50, 0
*spamApTask0: Oct 10 09:20:06.019: apModel: AIR-CAP3702I-N-K9
*spamApTask0: Oct 10 09:20:06.020: apType = 38 apModel: AIR-CAP3702I-N-K9
*spamApTask0: Oct 10 09:20:06.020: Unknown AP type. Using Controller Version!!!
*spamApTask0: Oct 10 09:20:06.020: 58:f3:9c:78:d1:10 Discovery Response sent to 10.37.24.116 port 41508
*spamApTask0: Oct 10 09:20:06.020: 58:f3:9c:78:d1:10 Discovery Response sent to 10.37.24.116:41508
*spamApTask0: Oct 10 09:20:06.021: 58:f3:9c:78:d1:10 Discovery Request from 10.37.24.116:41508
*spamApTask0: Oct 10 09:20:06.021: 58:f3:9c:78:d1:10 ApModel: AIR-CAP3702I-N-K9
*spamApTask0: Oct 10 09:20:06.021: 58:f3:9c:78:d1:10 Join Priority Processing status = 0, Incoming Ap's Priority 4, MaxLrads = 50, 0
*spamApTask0: Oct 10 09:20:06.021: apModel: AIR-CAP3702I-N-K9
*spamApTask0: Oct 10 09:20:06.021: apType = 38 apModel: AIR-CAP3702I-N-K9
*spamApTask0: Oct 10 09:20:06.021: Unknown AP type. Using Controller Version!!!
*spamApTask0: Oct 10 09:20:06.021: 58:f3:9c:78:d1:10 Discovery Response sent to 10.37.24.116 port 41508
*spamApTask0: Oct 10 09:20:06.021: 58:f3:9c:78:d1:10 Discovery Response sent to 10.37.24.116:41508
*spamApTask0: Oct 10 09:20:16.031: 58:f3:9c:7a:22:30 DTLS connection not found, creating new connection for 10:37:24:116 (41508) 10)
*spamApTask0: Oct 10 09:20:16.498: acDtlsPlumbControlPlaneKeys: lrad:10.37.24.116(41508) mwar:10.37.24.11(5246)
*spamApTask0: Oct 10 09:20:16.498: 58:f3:9c:7a:22:30 Allocated index from main list, Index: 55
*spamApTask0: Oct 10 09:20:16.498: 58:f3:9c:7a:22:30 Using CipherSuite AES128-SHA
*spamApTask0: Oct 10 09:20:16.499: 58:f3:9c:7a:22:30 DTLS keys for Control Plane are plumbed successfully for AP 10.37.24.116. Inde6
*spamApTask1: Oct 10 09:20:16.499: 58:f3:9c:7a:22:30 DTLS Session established server (10.37.24.11:5246), client (10.37.24.116:41508)
*spamApTask1: Oct 10 09:20:16.499: 58:f3:9c:7a:22:30 Starting wait join timer for AP: 10.37.24.116:41508
*spamApTask0: Oct 10 09:20:16.517: 58:f3:9c:78:d1:10 Join Request from 10.37.24.116:41508
*spamApTask0: Oct 10 09:20:16.517: 58:f3:9c:7a:22:30 Deleting AP entry 10.37.24.116:41508 from temporary database.
*spamApTask0: Oct 10 09:20:16.518: 58:f3:9c:7a:22:30 spamProcessJoinRequest : RAP, Check MAC filter
*spamApTask0: Oct 10 09:20:16.518: 58:f3:9c:78:d1:10 In AAA state 'Idle' for AP 58:f3:9c:78:d1:10
*spamApTask0: Oct 10 09:20:16.518: 58:f3:9c:7a:22:30 Mesh AP username 58f39c7a2230.
*spamApTask0: Oct 10 09:20:16.518: 58:f3:9c:78:d1:10 Join Request failed!
*spamApTask0: Oct 10 09:20:16.518: 58:f3:9c:78:d1:10 State machine handler: Failed to process  msg type = 3 state = 0 from 10.37.248
*spamApTask0: Oct 10 09:20:16.518: 58:f3:9c:7a:22:30 Failed to parse CAPWAP packet from 10.37.24.116:41508
*spamApTask0: Oct 10 09:20:16.519: XóxÑ
*spamApTask0: Oct 10 09:20:16.519: 58:f3:9c:78:d1:10 Finding DTLS connection to delete for AP (10:37:24:116/41508)
*spamApTask0: Oct 10 09:20:16.519: 58:f3:9c:78:d1:10 Disconnecting DTLS Capwap-Ctrl session 0x179437d8 for AP (10:37:24:116/41508)
*spamApTask0: Oct 10 09:20:16.519: 58:f3:9c:78:d1:10 CAPWAP State: Dtls tear down
*spamApTask0: Oct 10 09:20:16.520: acDtlsPlumbControlPlaneKeys: lrad:10.37.24.116(41508) mwar:10.37.24.11(5246)
*spamApTask0: Oct 10 09:20:16.520: 58:f3:9c:78:d1:10 DTLS keys for Control Plane deleted successfully for AP 10.37.24.116
*spamApTask0: Oct 10 09:20:16.526: 58:f3:9c:78:d1:10 DTLS connection closed event receivedserver (10.37.24.11/5246) client (10.37.2)
Sorry some more
Sorry some more information
the WLC version is 7.6.110.0
the current countrycode is mexico (-N)
VIP Purple
paste THE OUTPUT OF THESE.sh
sh sysinfo from WLC
sh auth-list from WLC
sh version from AP
also add the AP mac address to Security > AAA > AP policies
Hi all, the AP was in Mesh
Hi all, the AP was in Mesh (Bridge) mode and could not connect to the controller
Ok, how to find out that a AP is in bridge mode, without a join (No Access to the AP).
go to monitor > statistics > AP Join
you will see the AP here that tries to connect (clear the list before)
if the ethernet MAC Address is the same as the Base radio MAC, than the AP is in bridge mode.
normally ( in local mode) the Ethernet MAC Address reflects the APname
To allow the AP to join, add in the Authorization list the APName mac Address!
See: http://supertekboy.com/2014/01/13/cisco-lightweight-access-point-will-not-join-to-a-wireless-lan-controller/
The case is solved now.
Refer the link :https:/
1410
