AP's (AIR-CAP1552E-E-K9) are not abale to join WLC 5508
Dear all thanks for your time for this ,
i have WLC 5508 which is connected to 3750-x Switch (Which i am using As core switch) and in the 3750x switch i created 7 vlan's and 7' DHCP pool as per clinet request , and i have
AIR-LAP1141N-E-K9
802.11g/n Controller-based AP; Int Ant; ETSI Cfg
20
AIR-CAP1552E-E-K9
802.11a,b/g Outdoor Mesh AP, ETSI Cfg 1520 Series Mesh Access Points
these indoor and outdoor access points ,
i configure the WLC with SSID and management IP for the WLC Host name and Etc ,
and the configuration of Core switch and Configure the DHCP Pool with OPTION43 service ,
while i am trying to conntec the indoor AP its getting connected from Access switch with the Comman (capwap ap controller ip add x.x.x)
and its connected and working fine , its showing the SSID and every thign,
but while i am trying to connected the Outdoor AP with the same command (capwap ap controller ip add x,xxx and the other command Lwapp ap controller ip add xxx) its showing this error
find the out
APb4e9.b0c7.aa40#lwapp ap controller ip address 10.86.1.
*Jul 7 21:16:23.999: DTLS_CLIENT_ERROR: ../dtls/dtls_connection_db.c:2017 Max retransmission count reached!
*Jul 7 21:16:23.999: %DTLS-3-HANDSHAKE_RETRANSMIT: Max retransmit count for 10.86.1.254 is reached.254
APb4e9.b0c7.aa40#lwapp ap controller ip address 10.86.1.254
APb4e9.b0c7.aa40#
*Jul 7 21:16:54.039: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.86.1.254:5246
*Jul 7 21:15:54.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.86.1.254 peer_port: 5246
% CDP is not supported on this interface, or for this encapsulation
*Jul 7 21:16:00.707: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.86.1.254 peer_port: 5246
*Jul 7 21:16:00.707: %CAPWAP-5-SENDJOIN: sending Join Request to 10.86.1.254
*Jul 7 21:16:00.707: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jul 7 21:16:00.711: %DTLS-5-ALERT: Received WARNING : Close notify alert from 10.86.1.254
*Jul 7 21:16:00.711: %DTLS-5-PEER_DISCONNECT: Peer 10.86.1.254 has closed connection.
*Jul 7 21:16:00.711: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.86.1.254:5246
*Jul 7 21:16:00.755: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jul 7 21:16:00.807: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Jul 7 21:16:00.831: status of voice_diag_test from WLC is false
*Jul 7 21:16:02.203: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join timer expired
*Jul 7 21:16:02.203: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join failed expired
*Jul 7 21:16:02.203: %MESH-6-LINK_UPDOWN: Mesh station b4e9.b0c7.aa5c link Down
*Jul 7 21:17:11.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.86.1.254 peer_port: 5246
*Jul 7 21:17:11.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jul 7 21:17:27.603: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.86.1.254:5246
*Jul 7 21:17:27.603: %MESH-6-CAPWAP_RESTART: Mesh Capwap re-started
*Jul 7 21:17:11.711: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.86.1.254 peer_port: 5246
*Jul 7 21:17:11.711: %CAPWAP-5-SENDJOIN: sending Join Request to 10.86.1.254
*Jul 7 21:17:11.711: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jul 7 21:17:11.715: %DTLS-5-ALERT: Received WARNING : Close notify alert from 10.86.1.254
*Jul 7 21:17:11.715: %DTLS-5-PEER_DISCONNECT: Peer 10.86.1.254 has closed connection.
Hall of Fame Super Silver
Re: AP's (AIR-CAP1552E-E-K9) are not abale to join WLC 5508
Well with these mesh access points, they require a little more power and typically you need a power injector or a hard wired power connection. Now also with mesh, you need to add the mesh AP's MAC address to the Mac filter before it will be allowed to join.
Here is a mesh troubleshoot guide that should help also.
http://www.cisco.com/en/US/docs/wireless/access_point/1500/troubleshooting/guide/TrbleshtMesh.html
-Scott
Sorry Scott:
I was reading this post... so Aman need to agregate the MAC Address of every AP? with this they will join to th WLC ?
Only for mesh access points. This helps so that you don't start controlling others mesh AP's or your mesh AP's don't start joining a neighbors mesh network. You can always find out the mesh MAC address by looking at the logs or running a debug.
-Scott
Really sorry.
Mesh Access Point? I'm not sure about this there a different type of AP ? or different type of IOS?
I'm not sure if I'm undertandig this wrong but cisco have two types of AP: Autonomus and LWAP.
Any lightweight access point in bridge mode that is defined as a RAP or MAP or a 1520 and or 1550 in that mode.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Here is what I'm talking about and its a requirement for mesh.
http://www.cisco.com/en/US/docs/wireless/technology/mesh/7.0/design/guide/MeshAP_70.html
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_white_paper09186a0080b1c101.shtml
Scott
-Scott
Thank you so much
No problem... your right though regarding two types of access points.  One being autonomous and the other lightweight.
Scott
-Scott
1559
