Community Member
AP stuck in Default-Group
I have an access point that is stuck in my AP group. The AP group is the premade group called default group. I tried powering the AP down and clearing the config. This didn't work. The AP would never lose its name no matter how many times I cleared the config.
The AP is a 1131 and our controller is a 4404 with Software Version                 6.0.188.0.
Any ideas on what I should do?
Hall of Fame Super Silver
Re: AP stuck in Default-Group
Did you assign the AP to another group and did you try to set the AP Group under the WLAN Advanced AP Group tab or the AP Advanced tab?
-Scott
Community Member
I tried putting the ap in the AP group using  WLAN/advance/ap groups  and wireless/ap name/advance. When I tried it using the second method it give me this error: http://img708.imageshack.us/i/errora.jpg/
Is it just one AP.... if so, maybe beteer just to tftp the rcv image again and start from scratch.... take you less than 5 minutes.
-Scott
Community Member
do you know of any documentation on how to do this?
337
