AP will not join WLC
3702I AP will not join 5760 WLC
following is output form the AP
if anyone has any ideas would be appreciated
*Mar  1 00:33:57.035: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 172.16.239.148, mask 255.255.255.192, hostname APd072.dc03.8110
*Mar  1 00:34:02.915: %CAPWAP-5-DHCP_OPTION_43: Controller address 172.16.243.2 obtained through DHCP
*Mar  1 00:34:02.915: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:34:48.415: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Mar  1 00:34:53.427: %CAPWAP-3-ERRORLOG: Invalid event 40 & state 2 combination.
*Mar  1 00:34:53.535: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 172.16.239.149, mask 255.255.255.192, hostname APd072.dc03.8110
*Mar  1 00:34:59.415: %CAPWAP-5-DHCP_OPTION_43: Controller address 172.16.243.2 obtained through DHCP
*Mar  1 00:34:59.415: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:35:44.915: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Mar  1 00:35:49.935: %CAPWAP-3-ERRORLOG: Invalid event 40 & state 2 combination.
*Mar  1 00:35:50.035: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 172.16.239.150, mask 255.255.255.192, hostname APd072.dc03.8110
*Mar  1 00:35:55.915: %CAPWAP-5-DHCP_OPTION_43: Controller address 172.16.243.2 obtained through DHCP
*Mar  1 00:35:55.915: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:36:41.415: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Mar  1 00:36:46.431: %CAPWAP-3-ERRORLOG: Invalid event 40 & state 2 combination.
*Mar  1 00:36:46.535: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 172.16.239.151, mask 255.255.255.192, hostname APd072.dc03.8110
VIP Purple
Paste the output of these
Paste the output of these commands:
sh sysinfo from wlc
sh version from AP.
thanks for the reply outputs
thanks for the reply outputs below
APd072.dc03.8110#show version
Cisco IOS Software, C3700 Software (AP3G2-K9W8-M), Version 15.2(4)JB5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Thu 01-May-14 22:12 by prod_rel_team
ROM: Bootstrap program is C3700 boot loader
BOOTLDR: C3700 Boot Loader (AP3G2-BOOT-M) LoaderVersion 15.2(4)JB, RELEASE SOFTWARE (fc1)
APd072.dc03.8110 uptime is 23 hours, 29 minutes
System image file is "flash:/ap3g2-k9w8-mx.152-4.JB5/ap3g2-k9w8-xx.152-4.JB5"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP3702I-E-K9 (PowerPC) processor (revision A0) with 204790K/57344K bytes of memory.
Processor board ID FCZ1811J0ED
PowerPC CPU at 800MHz, revision number 0x2151
Last reset from power-on
LWAPP image version 7.6.100.0
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: D0:72:DC:03:81:10
Part Number                          : 73-15243-01
PCA Assembly Number                  : 000-00000-00
PCA Revision Number                  :
PCB Serial Number                    : FOC180825E1
Top Assembly Part Number             : 068-05054-01
Top Assembly Serial Number           : FCZ1811J0ED
Top Revision Number                  : A0
Product/Model Number                 : AIR-CAP3702I-E-K9
Configuration register is 0xF
APd072.dc03.8110#
the show sysinfo command does not work on the WLC
i have supplied a show version info from wlc
System image file is "flash:ct5760-ipservicesk9.SPA.03.03.03.SE.150-1.EZ3.bin"
Hall of Fame Super Gold
Is this the Management IP Address of the WLC?
Make sure that the CAPWAP UDP ports 5246 and 5247 (similar to the LWAPP UDP ports 12222 and 12223) are enabled by the firewall?
i believe so. first time
i believe so. first time using the 6700 wlc so the vlan with that address has the cli config stating is is the management
VIP Purple
HI Bernard,1. First check the
HI Bernard,
1. First check the date and time on WLC.
2. Paste the DHCP pool config here(specially DHCO option 43 hex string).
Ok, if you say FW has allowed
Ok, if you say FW has allowed those ports, then console into the AP and ping the WLC Management IP address of 172.16.243.2.  Tell us the result of the ping.
VIP Purple
Hi,1. What is the country
1. What is the country code configured on wlc?
2. AP(172.16.239.151) and WLC(172.16.243.2) are on diff. subnet, did you configured DHCP option 43 or which way AP will find about WLC:
-AP is getting ip via DHCP, please also add DHCP option 43 in that pool or try to put in same subnet as WLC.
- or use ip helper command: http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/70333-lap-registration.html
country code is GBoption 43
country code is GB
option 43 is set using hex value pointing to wlc ip
same error logs when AP is in same subnet
823
