Ap with one antenna
Hi guys,
any of you knows if thera are problem using Ap with only one antenna?
do they work?
drawbacks?
thanks
1 REPLY
Re: Ap with one antenna
that works fine, justo be sure that the antenna that you are using is 2.4 Ghz and is in the right side, cus the 5 Ghz must be plug the two conectors.
Usually the AP in one side says "PRIMARY", you must plug the antenna there.
112
