AP with Power Level 0
Hello community,
in the wireless LAN infrastructure of my customer, I noticed some 1142 Accesspoints with Power Level 0 (TPC). I tried to configure this via Prime (1.3) and directly at the Controller (5508, 7.0) but you can´t set it (the pull down menu is empty).  As far as I know, you can set the Power Level to 1-8. I only know this effect with autonomous Accesspoints migrated in Prime.
Does someone know what happens or how to fix it? Is it a known Bug?
Thank you in advance,
Benjamin
Everyone's tags (2)
Bronze
Re: AP with Power Level 0
what is the wlc code?
what is the power level if you see it on wlc?
Hi, it's code 7.0.240.0. On both controller and prime It looks the same: on some 1142 Accesspoints power level is set to "0" and I can't change it. I have to add, only 802.11a radios seem to have this problem.
I think the sw version is supported with prime 1.3
Benjamin
I think you may need to upgrade to the latest WLC version ie 7.4 to support this.
Hi, thank you for the answer. Hmmm...really? It´s a basic function to adjust the transmit power, therefore I guessed it would be a sw or hw bug. I plan to upgrade the sw due to some hardware change this year, maybe we catch it with this. Any other ideas? My hope was that somebody had this effect, too.
Benjamin
Can you upload the wlc sreenshot and show run config?
Hi, I'm not onsite and have no possibility to post the config. Thank you guys, if the problem isn't fixed after sw update I will open a SR.
Benjamin
283
