Ap1141n-Want only 802.11n, no 802.11g connects & speed
Have a Ap1141n running in Standalone AP mode. It is not running via a WLAN controller.
How to I set it up to only accept connection from 802.11n clients. I don't want any 802.11g clients making it slow down to 54g speed. Which brings up another queston, how do I set it up to do possible 150meg  connects that are possible with 11n?
Been searching around internet and cisco.com and nothing is jumping out at me.  would love to have someone's "sanatized" config file.
I have setup the the 1141 series with A/B/G radio's before, but this thing has got me stumped.
Everyone's tags (2)
First, I don't belive that it's supported for 'N' only at this time, you still need to have at least the 54M rate as supported.  But you can disable all the lower rates and only leave 54 enabled.
As to the second question, to achieve the N rates, you need the SSID to be configured for WPA2/AES or open.  No WPA/TKIP, no WEP etc.  Also WMM needs to be enabled, which it should be by default.
With the above you should be able to get up to 144Mbps on the 2.4GHz, and if you bond the 5GHz you can get up to 300M
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Re: Ap1141n-Want only 802.11n, no 802.11g connects & speed
So this 1141N will do higher than 54meg speeds with 1 radio?
Understood about disable <54meg speed.
What about using WPA2 enterprise (radius authentication) can I use that and acheive >54meg speeds
Bronze
Since the 1140 access point is an N access point it will be able to do higher data rates then 54 on either the A radio or G radio meanwhile you have wpa version 2 with AES enable or no encryption at all and also that the wireless client supports N.
if the wireless clients do not support N then they will only be able to work at 54mbps if from where the wireless client is located the signal qulity is good and distance to support 54 mbps if not it will not connect since you have disable the lower data rates.
Bronze
Correct, as mention above what you can do is leave 54 as required and all the n data rates enabl and with this the wireless clients would br able to work from 54mbps all the way to te max n data rate enable.
what are the "N" data rates?
Got an example of a config with 54 and > data rates only?
in the config the 'N' (MCS) rates show as m0 - m15.
Yes, you can use 802.1x, so long as you are set for WPA2/AES.
HTH,
Steve
Bronze
The N data rates are:
m0. , m1. , m2. , m3. , m4. , m5. , m6. , m7. , m8. , m9. , m10. , m11. , m12. ,  m13. , m14. , m15.
Here is a config example from an ap with no configuration at all, just all data rates disable on the G radio and with 54mbps as required and N enable.
version 12.4
no service pad
service password-encryption
hostname AP1142AG.246
enable secret 5 $1$LaFK$M1UNnyzJvTKn4e/NmiXBJ0
no aaa new-model
dot11 syslog
username Cisco password 7 062506324F41
bridge irb
interface Dot11Radio0
 no ip address
 no ip route-cache
 shutdown
 antenna gain 0
 speed  basic-54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
 station-role root
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
 bridge-group 1 spanning-disabled
interface Dot11Radio1
 no ip address
 no ip route-cache
 shutdown
 antenna gain 0
 dfs band 3 block
 channel dfs
 station-role root
 bridge-group 1
interface GigabitEthernet0
 no ip address
 no ip route-cache
 duplex auto
 speed auto
 no keepalive
 bridge-group 1
interface BVI1
 ip address dhcp client-id GigabitEthernet0
 no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
 login local
end
With this setup the AP will tell the allow the wireless clients to connect to the Ap if the connection is good for at least 54mbps or higher
Want to make sure everyone is aware I have the 1141N with only 1 radio. My 1141 isn't an A/B/G/N, but just a N/G single raido.
So I don't need to send these back and get the 1142N's eh?
I can get 54meg > speeds with this single radio 1141N.? Saw somewhere it was mentioned I needed a dual radio 1142n to get >54meg speeds achieved by "bonding" up the two radio's. Yes/no?
Yes you will still get N rates. That ap has two transmitters and three receivers for the 2.4GHz radio.
Bonding is when you group two channels together and can only be done on the 5GHz radio
Steve
Bronze
just in case the 1140 is an N access point, the only difference between one model of the other is that it can be supplied with both the 2.4ghz radio (B/G) or the 5GHZ radio (A)
Here is the link for the ordering guide of the 1140 where you can check on the different part numbers
http://www.cisco.com/en/US/prod/collateral/wireless/ps5678/ps10092/datasheet_c78-502797.html
On the A radio and the B/G radio you can support from 1mbps up to 54mbps, and since it is N you can get the N data rates to work also.
1751
