AP1142N "not supported AP" error at converting to LWAPP
Try to update an autonomous AP AIR-AP1142N-E-K9 (software C1140-K9W7M, version 12.4(21a)JA1 ) with the upgrade tool but get the error-message "not supported AP".  Tool version is: CiscoAironet-AP-to-LWAPP-Upgrade-Tool-v205.exe
Is it the conversion to Lwapp supported for the AP1142N and how can I convert?
Thanks for any help.
Alexander
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: AP1142N "not supported AP" error at converting to LWAPP
Here's another method:
Copy the LWAP IOS (with an "rcv" prefix in the filename) to the AP and let the AP boot that image.  Your AP can now join a WLC.
So simple, just use the cli and forget wizards and install tools It works!
Thanks for the ratings.
Hi, I have the same problem, but I do not how to fix, My WLC is 4402 and also I made a upgrade to the version 5.2.178, but it is the same. after that I make the upgrade to the AP for command (CLI) but it does not work. so Can you help me with this problem.
And also I do not understand how can I upgraded the IOS with the prefix rcv.
Can you post the bootup of your AP?
when the AP boot, show me the follow... and also can you tell me how can i make the upgrade with the prefix rcv?
IOS Bootloader - Starting system.
Xmodem file system is available.
DDR values used from system serial eeprom.
WRDTR,CLKTR: 0x82000800, 0x40000000
RQDC, RFDC : 0x80000037, 0x0000020a
PCIE0: link is up.
PCIE0: VC0 is active
PCIE1: link is up.
PCIE1: VC0 is active
PCIEx: initialization done
flashfs[0]: 150 files, 7 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 32385024
flashfs[0]: Bytes used: 5681664
flashfs[0]: Bytes available: 26703360
flashfs[0]: flashfs fsck took 18 seconds.
Reading cookie from system serial eeprom...Done
Base Ethernet MAC address: e0:5f:b9:85:97:80
Waiting for PHY auto negotiation to complete TIMEOUT !
done
Ethernet speed is 10 Mb - HALF duplex
The system has encountered an error initializing
the Ethernet port.
The system is ignoring the error and continuing to boot.
If you abort the system boot process, the following
commands will re-initialize Ethernet, TFTP, and finish
loading the operating system software:
    ether_init
    tftp_init
    boot
Loading "flash:/c1140-k9w7-mx.124-25d.JA/c1140-k9w7-mx.124-25d.JA"...#####################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################
File "flash:/c1140-k9w7-mx.124-25d.JA/c1140-k9w7-mx.124-25d.JA" uncompressed and installed, entry point: 0x4000
executing...
enet halted
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1140 Software (C1140-K9W7-M), Version 12.4(25d)JA, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Thu 09-Dec-10 15:24 by prod_rel_team
Proceeding with system init
Proceeding to unmask interrupts
Initializing flashfs...
FLASH CHIP:  Numonyx P33
Checking for Over Erased blocks
flashfs[1]: 150 files, 7 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 32126976
flashfs[1]: Bytes used: 5681664
flashfs[1]: Bytes available: 26445312
flashfs[1]: flashfs fsck took 5 seconds.
flashfs[1]: Initialization complete.
flashfs[2]: 0 files, 1 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 11999232
flashfs[2]: Bytes used: 1024
flashfs[2]: Bytes available: 11998208
flashfs[2]: flashfs fsck took 0 seconds.
flashfs[2]: Initialization complete....done Initializing flashfs.
Radio0  present 8363 8000 90020000 0 90030000 B
Radio1  present 8363 8000 98020000 0 98030000 0
Ethernet speed is 1000 Mb - FULL duplex
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html you require further assistance please contact us by sending email to
export@cisco.com. AIR-AP1142N-A-K9     (PowerPC405ex) processor (revision B0) with 98294K/32768K bytes of memory.
Processor board ID FTX1451K4NK
PowerPC405ex CPU at 586Mhz, revision number 0x147E
Last reset from power-on
1 Gigabit Ethernet interface
2 802.11 Radio(s)
If
cisco
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: E0:5F:B9:85:97:80
Part Number                          : 73-11451-08
PCA Assembly Number                  : 800-30554-06
PCA Revision Number                  : A0
PCB Serial Number                    : FOC144862YW
Top Assembly Part Number             : 800-31273-04
Top Assembly Serial Number           : FTX1451K4NK
Top Revision Number                  : A0
Product/Model Number                 : AIR-AP1142N-A-K9
Press RETURN to get started!
*Mar  1 00:00:07.828: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:07.842: *** CRASH_LOG = YES
*Mar  1 00:00:09.125: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:00:09.692: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1Base Ethernet MAC address: E0:5F:B9:85:97:80
*Mar  1 00:00:11.894: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:12.060: %SYS-5-CONFIG_I: Configured from memory by console
*Mar  1 00:00:12.063: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:12.063: %SNMP-5-COLDSTART: SNMP agent on host ap is undergoing a cold start
*Mar  1 02:03:13.006: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Mar  1 02:03:13.006: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Mar  1 02:03:13.819: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar  1 02:03:13.950: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  1 02:03:14.005: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 02:03:14.005: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Mar  1 02:03:27.641: %CDP_PD-4-POWER_OK: Full power - INJECTOR_CONFIGURED_ON_SOURCE inline power source
*Mar  1 02:03:49.124: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.191.11.17, mask 255.255.255.0, hostname ap
ap>
To copy the file from your TFTP server to the AP, the command is "archive download-sw tftp:///filename.tar".
Dear Leo, right now the ap is lightweight but it show me this, so it can not contact with te controller, do u know why?
using  eeprom values
WRDTR,CLKTR: 0x82000800 0x40000000
RQDC ,RFDC : 0x80000037 0x0000020a
ddr init done
PCIE0: link is up.
PCIE1: link is up.
flashfs[0]: 9 files, 2 directories
flashfs[0]: Bytes used: 4560896
flashfs[0]: Bytes available: 27824128
flashfs[0]: flashfs fsck took 17 seconds.
Loading "flash:/c1140-rcvk9w8-mx/c1140-rcvk9w8-mx"...###########################        ###################################################################################################
File "flash:/c1140-rcvk9w8-mx/c1140-rcvk9w8-mx" uncompressed and installed, entry point: 0x4000
executing...
enet halted
           cisco Systems, Inc.
Cisco IOS Software, C1140 Software (C1140-RCVK9W8-M), Version 12.4(21a)JA2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 02-Nov-09 18:35 by prod_rel_team
flashfs[1]: 9 files, 2 directories
flashfs[1]: Total bytes: 32385024
flashfs[1]: Bytes used: 4560896
flashfs[1]: Bytes available: 27824128
flashfs[1]: Initialization complete....done Initializing flashfs.
LWAPP image version 3.0.51.0
If
cisco
% Please define a domain-name first.
Translating "CISCO-LWAPP-CONTROLLER"...domain server (255.255.255.255)
*Mar  1 00:00:06.426: *** CRASH_LOG = YES
*Mar  1 00:00:06.616: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 6 messages)
*Mar  1 00:00:08.665: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:08.682: %SYS-5-RESTART: System restarted --
*Mar  1 02:21:42.981: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (255.255.255.255)
*Mar  1 02:21:51.020: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-LWAPP-CONTROLLER
*Mar  1 02:22:00.020: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
eap profile lwapp_eap_profile
% Invalid input detected at '^' marker.
method fast
no dot1x credentials lwapp_credentials
no dot1x eap profile lwapp_eap_profile
*Mar  1 02:22:00.021: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
APe05f.b985.9780>
*Mar  1 02:22:11.134: %CDP_PD-2-POWER_LOW: All radios disabled - INJECTOR_CONFIGURED_ON_SOURCE WS-C2960G-24TC-L (0021.1ba8.1591)
APe05f.b985.9780>
Also always show me this error:
thanks Leo, I could fix the problem
Problem fixed?
yes, thanks for help.
The AP is stil in Autonomous Mode.. we need t oconvert the same and here is the process to do it..
https://supportforums.cisco.com/docs/DOC-14960
And we cannot use the Upgrade tool for 1140 series AP and its not supported. .we need to do it manually.. The mode button procedure will be shared by Leo now Wat say Leo??
Surendra
7024
