Community Member
ap1231 and ipod touch
Hi to all,
i need to configure an ap1231 for the ipod touch, the ap is already configurated for tkip but the ipod doesn't support this type of cypher.
I'm not sure about the resolution of this issue, i can use wpa migration configuring tkip/wep128? Or is better to configure another ssid on the same radio interface?
Thanks to all and best regards,
Carlo S.
Re: ap1231 and ipod touch
Seems that you are not alone on this matter:
http://www.ipodtouchfans.com/forums/archive/index.php?t-34648.html
Have you tried changing tkip to aes?
Community Member
I know that i'm not alone...
i have read the thread and i don't have already tryed to configure aes.
Is the very first time i modify a configuration that is working fine with other equipment, but if i don't try i don't know!
Is possible to configure 2 ssid for the same vlan?
Community Member
I'm trying now to change tkip in aes-ccm but seems windows cannot connect to the wireless network.
I have only changed the cipher mode to aes-ccm...i must change other element?
Community Member
I don't understand why i cannot see the wireless network if i use aes-ccm, i changed cipher from tkip to aes-ccm, but if i try to connect from win xp i cannot join the wireless network....
If i change the cipher i must configure other things?
The key management is always wpa i really don't know what can i do!
In the lwapp setup you can bind multiple ssids to the same vlan, not sure about autonomous mode though.. same bridge group for multiple ssids? never tried it
152
