AP1232AGs in a building to building wirelss trunking VLANs
I've been searching for some config examples, but don't seem to be coming up with much on this. I have 2 AP1232s that I'd like to use temporarily as a building to building wireless bridge to trunk 6 VLANs to my new office (100 yards away). I've got a 3524POE on one side and a 6509 on the other. I'd like to use the APs in bridge mode to simply connect the two trunk ports together.
I've been playing with these things for a few hours now, and don't seem to be having any luck. Even with getting them to pass traffic without VLANs. They're associated with each other (one is set as a root bridge, the other as a non-root bridge) and that's about it...no traffic is passing.
Does anyone know of a config example of s setup somewhere close to this that I can take a look at? I know these might not be the optimal equipment for the job, but thery're very temporary (they'll end up being the APs in the new space once I'm done moving servers and circuits over).
Thanks in advance,
Daryl
Re: AP1232AGs in a building to building wirelss trunking VLANs
Are you able to ping from the root bridge to the non-root bridge? Try using the following document, This document explains with a configuration example on how to configure point to point links using Wireless bridges.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008058f53e.shtml
1. Create a native Vlan on both devices. My advice is to use the same Vlan you used for switch management. Switchport config for 6509 and 3524:
Switchport mode trunk
Switchport trunk native vlan xxx
Switchport trunk encapsulation dot1q (if supported)
Switchport nonegotiate
2. Create a infrastructure SSID for the native Vlan. Set proper encryption for this Vlan and SSID. If you can WPA2 should be used (Cipher AES CCMP + TKIP).
3. Create the other Vlans you will trunk on both bridges. Its not neccesary to set any encryption or create SSIDs to theese Vlans.
171
