Community Member
AP1240 discovers but does not join WLC2006
WLC2006 and AP1240 are connected to the same subnet. WLC2006 addresses are 192.168.24.18 port 1 for the management interface and 192.168.24.25 port 2 for the ap-manager interface (see <<wlc_config_070105_145300.txt>> issued from show run-config). AP address is 192.168.24.20 and the controller address is 192.168.24.18.
The discovery phase seems OK. Then the AP sends a CNTL JOIN_REQUEST. No answer is provided by the WLC which acts as if it does not receive the request (see WLC traces <<wlc_070105_123000.txt>> and AP traces <<ap_070105_123000.txt>>). Ethereal traces captured on the same hub than WLC are attached (<<ethereal_070105_172400.txt>>).
What is badly set in the configurations?
Thanks by advance for your help.
Alain-Claude
Community Member
Re: AP1240 discovers but does not join WLC2006
The port of the ap-manager interface has been changed from 2 to 1. It is better and the AP joins now the WLC. But a problem occurs in the state IMAGE.
AP traces are:
*Mar 1 00:00:36.071: %LWAPP-5-CHANGED: LWAPP changed state to JOIN
examining image...
Loading file /c1240...
*Jan 8 16:10:41.113: %LWAPP-5-CHANGED: LWAPP changed state to IMAGE
%Error opening (Protocol error)archive download: takes 6 seconds
*Jan 8 16:10:47.113: LWAPP_CLIENT_ERROR_DEBUG: Retransmission count for packet exceeded more than max(IMAGE_DATA , 1)
*Jan 8 16:10:47.113: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
*Jan 8 16:10:47.114: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
*Jan 8 16:10:47.116: LWAPP_CLIENT_ERROR: not receive read response(3)
*Jan 8 16:10:47.120: lwapp_image_proc: unable to open tar file
*Jan 8 16:10:47.155: %SYS-5-RELOAD: Reload requested by lwapp image download proc. Reload Reason: Reason unspecified.
*Jan 8 16:10:47.155: %LWAPP-5-CHANGED: LWAPP changed state to DOWN
WLC traces are:
Mon Jan 8 16:09:38 2007: Successfully transmission of LWAPP Join-Reply to AP 00:19:2f:7e:53:02
Mon Jan 8 16:09:40 2007: Received LWAPP IMAGE_DATA from AP 00:19:2f:7e:53:02
Mon Jan 8 16:09:40 2007: Refusing image download to AP 00:19:2f:7e:53:02 - Unable to open file /bsn/ap//c1240
Mon Jan 8 16:09:40 2007: Processing of Image Data failed from AP 00:19:2f:7e:53:02
Mon Jan 8 16:09:41 2007: Received LWAPP IMAGE_DATA from AP 00:19:2f:7e:53:02
Mon Jan 8 16:09:41 2007: Failed decryption of message from AP 00:19:2F:7E:53:02
Mon Jan 8 16:09:41 2007: Security processing of Image Data failed from AP 00:19:2f:7e:53:02
Mon Jan 8 16:09:42 2007: Received LWAPP IMAGE_DATA from AP 00:19:2f:7e:53:02
Mon Jan 8 16:09:42 2007: Failed decryption of message from AP 00:19:2F:7E:53:02
Mon Jan 8 16:09:42 2007: Security processing of Image Data failed from AP 00:19:2f:7e:53:02
Mon Jan 8 16:09:43 2007: Received LWAPP IMAGE_DATA from AP 00:19:2f:7e:53:02
Mon Jan 8 16:09:43 2007: Failed decryption of message from AP 00:19:2F:7E:53:02
Mon Jan 8 16:09:43 2007: Security processing of Image Data failed from AP 00:19:2f:7e:53:02
Mon Jan 8 16:09:44 2007: Received LWAPP IMAGE_DATA from AP 00:19:2f:7e:53:02
Mon Jan 8 16:09:44 2007: Failed decryption of message from AP 00:19:2F:7E:53:02
Mon Jan 8 16:09:44 2007: Security processing of Image Data failed from AP 00:19:2f:7e:53:02
Mon Jan 8 16:09:45 2007: Received LWAPP IMAGE_DATA from AP 00:19:2f:7e:53:02
Mon Jan 8 16:09:45 2007: Failed decryption of message from AP 00:19:2F:7E:53:02
Mon Jan 8 16:09:45 2007: Security processing of Image Data failed from AP 00:19:2f:7e:53:02
Mon Jan 8 16:09:46 2007: Received LWAPP DISCOVERY REQUEST from AP 00:19:2f:7e:53:02 to 00:0b:85:47:df:80 on port '1'
Mon Jan 8 16:09:46 2007: spamDeleteLCB: stats timer not initialized for AP 00:19:2f:7e:53:02
Mon Jan 8 16:09:46 2007: Successful transmission of LWAPP Discovery-Response to AP 00:19:2f:7e:53:02 on Port 1
What does that mean?
Thanks for your help
Best Regards,
Alain-Claude
Hi Alain,
I believe you are running 3.2.78.0 on your controller and it looks to be the image related issue.
I will recommend you to upgrade to 3.2.150.10 or the later one in 4.0 release.
Ankur
Community Member
Hi Ankur,
Thanks for the advice. I will try and let you know.
Best Regards,
Alain-Claude
Community Member
Hi Ankur,
I have downloaded and installed the release 4.0 as you recommended (file <>.
It looks operating correctly. The case can be close.
Again thanks.
Have a nice weekend
Alain-Claude
209
