AP1240 problem
kamarul83
hi..
Do you have any idea why the radio will disable after i configure the AP1240 as workgroup bridge?
24 Replies 24
andrew.prince
Level 10
Level 10
First of all, thanks for your reply.
After I configured the AP1240, the software status still disabled and the hardware still down.
FYI, I have two of AP1240 and one 1300 Series Outdoor. For the AP1240, i configured as WGB and 1300 as Access Point.
Before this, all device working properly until last month. The AP1240 doesnt work but the 1300 Outdoor still working properly.
Did you have any idea what happen to my AP1240?
Can you post your current config?
Below is the configuration that i copy for config.txt
version 12.3
no service pad
service password-encryption
hostname ap
enable secret 5 $1$Gl9g$EL6iBO/Yfu.fskfJiY1rI.
ip subnet-zero
ip domain name m
no aaa new-model
dot11 ssid Myport
authentication open
power inline negotiation prestandard source
crypto pki trustpoint TP-self-signed-1842759256
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1842759256
revocation-check none
rsakeypair TP-self-signed-1842759256
crypto ca certificate chain TP-self-signed-1842759256
certificate self-signed 01 nvram:IOS-Self-Sig#3601.cer
username Cisco password 7 032752180500
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid Myport
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role workgroup-bridge
infrastructure-client
bridge-group 1
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
hold-queue 160 in
interface BVI1
ip address 192.168.1.134 255.255.255.0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
control-plane
bridge 1 route ip
line con 0
line vty 0 4
login local
end
Is this your current config?
I have checked you config - try the below:-
dot11 ssid Myport
infrastructure-ssid optional
or
infrastructure-ssid
then
inteface dot11radio0
no shut
test and post results?
I'm sorry. I'm not really understand. Could you please explain it to me?
I'm sorry. What do you mean Interface dot11radio0 no shut?
The wireless radio interface is current closed. To open the radio interface so wireless works - you must open it:- no shutdown is the command.
I've already select enable for the radio but the radio still =disable/down.
Below is the config;-
version 12.3
no service pad
hostname ap
ip subnet-zero
ip domain name m
no aaa new-model
dot11 ssid Myport
authentication open
bridge irb
no ip address
no ip route-cache
ssid Myport
bridge-group 1
no ip address
no ip route-cache
shutdown
station-role root
bridge-group 1
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
hold-queue 160 in
interface BVI1
no ip route-cache
ip http server
control-plane
bridge 1 route ip
line con 0
line vty 0 4
login local
end
Try this:-
no infrastructure-client
no shut
test - and post any information from the command line.
version 12.3
no service pad
hostname ap
enable secret xxx
ip subnet-zero
ip domain name m
no aaa new-model
dot11 ssid client
authentication open
username Cisco password xxx
bridge irb
no ip address
no ip route-cache
ssid client
bridge-group 1
no ip address
no ip route-cache
shutdown
station-role root
bridge-group 1
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
hold-queue 160 in
interface BVI1
no ip route-cache
ip http server
control-plane
bridge 1 route ip
line con 0
line vty 0 4
login local
end
You have changed the SSID - WHY? and you have not REMOVED "infrastructure-client" - WHY?
