AP1240 problem
kamarul83
hi..
Do you have any idea why the radio will disable after i configure the AP1240 as workgroup bridge?
24 Replies 24
oh. i'm sorry. i thought you want me to change the SSID. Do you mean the Client Authentication Setting?
Tell you what - can you post the primary's AP configuration the "root" and re-post the current 1240 ap configuration the "workgroup bridge"
I will take them into my lab and test them?
FYI, for the primary AP (1300 series outdoor)still on the site.
below is current 1240AP:-
version 12.3
no service pad
service password-encryption
hostname ap
enable secret xxx.
ip subnet-zero
ip domain name m
no aaa new-model
dot11 ssid client
authentication open
power inline negotiation prestandard source
crypto pki trustpoint TP-self-signed-1842759256
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1842759256
revocation-check none
rsakeypair TP-self-signed-1842759256
crypto ca certificate chain TP-self-signed-1842759256
certificate self-signed 01 nvram:IOS-Self-Sig#3601.cer
username Cisco password 7 032752180500
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid client
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role workgroup-bridge
infrastructure-client
bridge-group 1
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
hold-queue 160 in
interface BVI1
ip address 192.168.1.134 255.255.255.0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
control-plane
bridge 1 route ip
line con 0
line vty 0 4
login local
end
do you have the config for the 1300 AP? Do you know what the root SSID is configured on the 1300AP?? Without this information - this issue cannot be resolved.
OK - so I have been in my lab and found the following that would create the same situation that you are seeing:-
1) The radio interface on the root AP is down - then the workgroup ap radio interface would not come up.
2)The radio interface on the root AP as an ssid - then the workgroup ap radio interface has a different ssid in the radio interface, then it would not come up.
3) The radio interface on the root AP has encryption enabled - then the workgroup ap radio without the same encryption on the interface would not come up.
4) The radio interface on the root AP has encryption enabled, with a pre-shared key - then the workgroup ap radio with the same encryption but no pre-shared key on the interface would not come up.
5) The workgoup bridge AP is not close enough to the current root AP.
The above is all I could test in my lunch hour.
HTH.
Thanks.
I will let you know if i have a AP1300 Series configuration.
Also keep you update if there have a improvement of AP1240.
andrew I wanted to say thanks for posting this link. I've been wrestling for hours with my AP1242AG access point and could not get it to work as a bridge but the link you gave cleared it all up.
Cheers, Tony
If clustering is enabled on the WAP, a pop-up will notify you to disable clustering in order for the WorkGroup Bridge to work. Click OK to continue. To disable clustering, choose Single Point Setup from the navigation pane then choose Access Points > Disable Single Point Setup.
 Click the radio interface for the WorkGroup Bridge. When you configure one radio as a WorkGroup Bridge, the other radio remains operational. The radio interfaces correspond to the radio frequency bands of the WAP. The WAP is equipped to broadcast on two different radio interfaces. Configuring settings for one radio interface will not affect the other. Radio interface options may vary depending on the WAP model. Some WAPs show Radio 1 as 2.4 GHz while some have Radio 2 as 2.4 GHz.
The dual-radio fallback features allows you to configure access points so that if the non-root bridge link connecting the access point to the network infrastructure goes down, the root access point link through which a client connects to the access point shut down. Shutting down the root access point link causes the client to roam to another access point. Without this feature, the client remains connected to the access point, but won't be able to send or receive data from the network.
This feature is supported by the dual-radio access points such as AP1240, AP1230, and AP 1130.
This feature does not affect the fallback feature for single-radio access points.
You can configure dual-radio fallback in three ways:
•Radio tracking
•Fast Ethernet tracking
•MAC-address tracking
You use the data rate settings to choose the data rates the wireless device uses for data transmission. The rates are expressed in megabits per second. The wireless device always attempts to transmit at the highest data rate set to Basic, also called Require on the browser-based interface. If there are obstacles or interference, the wireless device steps down to the highest rate that allows data transmission. You can set each data rate to one of three states:
•Basic (the GUI labels Basic rates as Required)—Allows transmission at this rate for all packets, both unicast and multicast. At least one of the wireless device's data rates must be set to Basic.
•Enabled—The wireless device transmits only unicast packets at this rate; multicast packets are sent at one of the data rates set to Basic.
•Disabled—The wireless device does not transmit data at this rate.
@sbhadrav
This topic is from 2008, you probably didn't need to comment on it :P
Please rate helpful / correct posts
