06-03-2012 05:36 AM - edited 07-03-2021 10:14 PM
Hi all.
I have seven autonomous AP1242AG (c1240-k9w7-tar.124-25d). Can I configure them to a mesh without WLC?
AP_r1 -> AP_r2 -> AP_r3
Root-AP
AP_l1 -> AP_l2 -> AP_l3
A cisco technician told me that's possible. But I cannot find any how to's.
Best regards
Olaf
Solved! Go to Solution.
06-03-2012 06:37 AM
You can do this with the IOS AP. the configuration on the main is root, and all the others will be a repeater.
Now do keep in mind that at every hop you are going to essentially lose half of the bandwidth. So I you start with a connection of 48M the next will be 24, then 12, and so forth.
Steve
06-03-2012 06:37 AM
Steve
06-03-2012 04:18 PM
Hi Steve.
Thanks for your suggestion. It works.
I use the 802.11a for backhaul and 802.11g for client traffic. For this I set the RAP in 802.11a to "Access Point" and all other APs to "Repeater" with a "parent configuration". In 802.11g I set all APs to "Access Point". For authentication I use WPA2 in A and G.
Best regards
Olaf
