AP1261N Upgrade tool not supported
I have an AP 1261N that i wish to convert to LWAPP but when i try the upgrade tool it says that it is not supported.
Below is the log i recieve from the tool:
2013/10/02 10:47:46 DEBUG      172.22.200.201      Validating IP address
2013/10/02 10:47:46 DEBUG      172.22.200.201      Opening a telnet connection to the AP
2013/10/02 10:47:48 INFO      172.22.200.201      User  has  Full privilege
2013/10/02 10:47:48 INFO      172.22.200.201      Getting  AP Name
2013/10/02 10:47:48 DEBUG      172.22.200.201      Verify if APs image is 12.3(07)JA or greater
2013/10/02 10:47:48 INFO      172.22.200.201      AP  has 12.3(7)JA Image or greater
2013/10/02 10:47:48 DEBUG      172.22.200.201      Identifying the AP Type
2013/10/02 10:47:48 INFO      172.22.200.201      Term Length configured.
2013/10/02 10:47:48 ERROR      172.22.200.201      AP is not supported by the Upgrade Tool
Is there a newer version for the upgrade tool to support 1260 series or the AP itself cannot be converted?
if it cannot be converted can someone direct me to a post or link of AP models that cannot be converted.
Thanks!
Hall of Fame Super Gold
If you want to upgrade to CAPWAP, then just copy the "RCV" file into the AP, change the boot string and presto! you are done.
Hi Leo,
Are all APs that have LAP counter parts can be converted this way? how do I change the bootstring? Do I still need to extract it?
config t
boot system flash:directory/IOS_filename.bin
end
wr
reload
Yes you do.  Use the "archive download-sw" command to self-extract.
Hi Leo,
I will try this method sometime next week. another question, do i have to delete the IOS on the AP for this to work?
That's optional because once the AP joins the controller, the controller will then push the full CAPWAP IOS and overwrite-and-delete the autonomous IOS.
For me, I always delete the autonomous IOS because I'm too lazy to change the boot string.  LOL!
Download the LWAPP image(W8) from the cisco website and get the console access the AP and just issue the command..
archive download-sw/overwrite/force-reload tftfp:////
174
