AP1532's acting as P2P Bridges
I have 2 AP1532's working in autonomous mode, configured as a p2p bridge (Root and non-Root) and can not get them in a basic configuration to assocaite with each other.
Here are the configurations;
***ROOT***
hostname MESL-INT-AP-ROOT
no aaa new-model
no ip cef
dot11 syslog
dot11 ssid MESL-OUTSIDE
   vlan 127
   authentication open
   authentication key-management wpa version 2
   wpa-psk ascii 7 143A37382049051E101B1A1107
dot11 guest
username Cisco password 7 032752180500
username mrlict privilege 15 password 7 09785B2B1B3F4C374A1F
bridge irb
interface Dot11Radio0
 no ip address
 antenna gain 0
 packet retries 64 drop-packet
 station-role root
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 spanning-disabled
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
interface Dot11Radio1
 no ip address
 encryption vlan 127 mode ciphers aes-ccm
 ssid MESL-OUTSIDE
 antenna gain 0
 peakdetect
 no dfs band block
 channel dfs
 station-role root bridge
interface Dot11Radio1.127
 encapsulation dot1Q 127 native
 bridge-group 1
interface GigabitEthernet0
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0.127
 bridge-group 1
interface GigabitEthernet1
 no ip address
 duplex auto
 speed auto
 bridge-group 1
interface BVI1
 ip address 10.100.7.10 255.255.0.0
 ipv6 address dhcp
 ipv6 address autoconfig
 ipv6 enable
ip default-gateway 10.100.3.1
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
***NON_ROOT***
hostname MESL-OUTSIDE-AP-NONROOT
logging rate-limit console 9
enable secret 5 $1$OZAS$B6R7tfgfdqeX8xl2uNHpJ0
no aaa new-model
no ip cef
dot11 syslog
   vlan 127
   authentication open
   wpa-psk ascii 7 00293635281624333B12656A2C
dot11 guest
bridge irb
 no ip address
 antenna gain 0
 station-role root
 bridge-group 1
 no ip address
 ssid MESL-OUTSIDE
 antenna gain 0
 peakdetect
 station-role non-root bridge
 bridge-group 1
 no ip address
 duplex auto
 speed auto
 bridge-group 1
 no ip address
 duplex auto
 speed auto
 bridge-group 1
interface BVI1
 ip address 10.100.7.11 255.255.0.0
 ipv6 address dhcp
 ipv6 enable
ip http server
bridge 1 route ip
I do not see the other AP from the root. Is there any other debug that I could do to confirm where the problem is?
MESL-INT-AP-ROOT#sh dot11 associations
<None>
MESL-INT-AP-NONROOT#Interface Dot11Radio1, cannot associate: No Response
Thanks in advance.
VIP Purple
HiTry to put "infrastructure
Try to put "infrastructure-ssid" under your SSID configuration  in both ROOT-BRIDGE & NON-ROOT-BRIDGE.
Here is working configuration for a Bridge with EAP-FAST. But you should be able to simply modify the security config to WPA2/PSK
http://mrncciew.com/2013/11/09/wireless-bridge-with-eap-fast/
Rasika
**** Pls rate all useful responses ****
Thanks Rasika.My issue was
Thanks Rasika.
My issue was actually related to the POE attached Switch not negotiating the correct power (only gave 15W) which resulted in not enough power being available to enable the radios.
Once I statically configured the power (also added "infrastructure-ssid") everything works fine.
Thanks again.
106
