08-21-2014 03:45 AM - edited 07-05-2021 01:24 AM
I installed virtual 2500 WLC on ESX server. Customer has 3 AP's but one of them can not join to WLC altough has same switch configuration with other them. When I connecting with console cable to not joined AP below outputs shown.
*Aug 15 18:01:35.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.224.0.71:5246
*Aug 15 18:01:36.035: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Aug 15 18:01:36.047: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Aug 15 18:01:36.047: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Aug 15 18:01:36.059: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Aug 15 18:01:36.075: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Aug 15 18:01:37.047: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Aug 15 18:01:37.087: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Aug 15 18:01:37.095: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Aug 15 18:01:38.079: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Aug 15 18:01:38.087: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Aug 15 18:01:38.115: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Aug 15 18:01:38.123: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Aug 15 18:01:38.131: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Aug 15 18:01:39.115: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Aug 15 18:01:39.123: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Aug 15 18:01:39.151: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Aug 15 18:01:40.151: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Aug 15 18:01:46.075: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Aug 15 18:02:46.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.224.0.71 peer_port: 5246
*Aug 15 18:03:15.999: DTLS_CLIENT_ERROR: ../capwap/base_capwap/dtls/base_capwap_dtls_connection_db.c:2051 Max retransmission count reached!
Why AP can not join to WLC? What is desciption of these logs?
Burhan,
08-22-2014 04:24 AM
Hi Burhan,
The AP has learn that the management IPv4 address of your vWLC is 10.224.0.71, is this correct? If you login to the AP, can you ping that IPv4 address? If not, please check of the ARP table is populated. Also is the vWLC connected to two different VLANs in VMware (one for management and one for the serviceport?) If not, please change that.
If the problems than still occur, could you include the output of the following commands?
08-22-2014 04:59 AM
Hi Freerk,
vWLC ip address is 10.224.0.71. When I login to the AP I can ping to vWLC.
In same situation, other two AP's (has same code and product) registered to vWLC. I saw same errof logs these AP's but after one day 2 AP's has registered. I have no idea why 2 AP's registered to vWLC why did note register 1 AP in same situation when I saw same error logs all AP's console.
Note : There is no license problem. vWLC has 10 AP's license.
When I am on customer site, I will collect these command outputs and provide.
Burhan,
08-22-2014 04:42 AM
Please verify the code on both wlc and AP.
08-22-2014 05:00 AM
Hi Mohana,
There are 2 AP's with same code with this AP but these are registered to vWLC. I think all of them has same code.
But if you need code name I will inform when I learn.
