01-12-2014 06:05 AM - edited 07-04-2021 11:56 PM
What is the configuration of cisco ap2602 in order to connect with dsl and enabling standalone dhcp..
My ap ssid is accessible but no internet browing and dhcp is not workin
Plz help
01-14-2014 01:40 AM
HI Rasheed,
About your issue, you better go for Aironet IOS configuratoin guide. It is the config guide for autonomouse mode.
Also, there are many configure examples for autonomouse APs in Cisco site.
Check this config guide for example:
http://www.cisco.com/en/US/docs/wireless/access_point/12.4_10b_JA/configuration/guide/scg12410b.html
Check the config examples right here:
http://www.cisco.com/en/US/products/hw/wireless/ps430/prod_configuration_examples_list.html
Also check this thread: https://supportforums.cisco.com/thread/2202297
Hope this helps.
01-14-2014 01:47 AM
If your DSL router/modem provide DHCP then a simple configuration like this on your 2602 should work.
hostname
dot11 ssid
authentication open
authentication key-management wpa version 2
guest-mode
wpa-psk ascii
interface Dot11Radio0
encryption mode ciphers aes-ccm
ssid
no shutdown
interface Dot11Radio1
ssid
no shutdown
interface BVI1
ip address dhcp
Rasika
**** Pls rate all useful responses ****
01-14-2014 08:15 AM
no dsl modem does not provide dhcp..
one more thing is that internet got browsing on client if manually dns is entered.
plz reply ..
01-14-2014 08:20 AM
The AP doesn't do NAT, so you need a router to do the NAT. The router would be able to perform DHCP also.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
01-14-2014 09:45 AM
Where is DHCP defined ? If everything done on AP please attach show run config of your AP to check.
Rasika
01-15-2014 08:47 PM
we are using proxy server..we have tmg server from which we are giving dsl to users.
on one dsl i want to connect this ap...
no dhcp is defined in windows server.
01-27-2014 10:36 PM
looking forward for ur help..same issue persist.dhcp is not working...client get internet access when proxy is added..
01-15-2014 08:48 PM
01-16-2014 03:01 AM
HI Amber,
configure access point as a DHCP server:
AP# configure terminal
AP(config)# ip dhcp excluded-address 172.16.1.100 172.16.1.xyz
AP(config)# ip dhcp pool test
AP(dhcp-config)# network 172.16.1.0 255.255.255.0
AP(dhcp-config)# lease 10
AP(dhcp-config)# end
for more info...paste your topology diagramm.
01-27-2014 02:27 AM
still dhcp not working and no internet browsing at client side...
01-16-2014 04:10 AM
Just to add.... here is the configuration guide for the code you are running on your access points. Use this as a reference in case you get stuck on certain aspects of the configuration.
http://www.cisco.com/en/US/docs/wireless/access_point/15_2_4_JA/configuration/guide/scg15.2.4JA.pdf
Here is another good support guide with basic configuration settings for autonomous AP"s
https://supportforums.cisco.com/docs/DOC-16087
Scott
