03-05-2004 05:36 AM - edited 07-04-2021 09:25 AM
Any one els have problem with
getting ip by dhpc while you have
enable the wep 128 on the ap
and then enable wep 128 on a client
If i disable the wep on the client
i get an ip and when i connect to the
ap and log on to it, i see that
wep is enable, but , why can i connect
to it when i have disable the wep
on my client , it shouldnt work
or is it someting i dont understand ?
and on the ap , i can choose optional and mandantory
wep , whats the diff ?
maybe its easier to use mac filtering ? but
is that any secure still , some one can sniff packets i guess ?
regards Thomas
03-07-2004 01:36 AM
That is because your AP is allowing Open Authentication. WIth Open authentication, even if the WEP key is not configured you will be allowed access to the network. Choose Mandatory option on the AP and then you will see the difference. Clients with no wep will be denied access to the network.
I think your problem with not getting DHCP when WEP key is on (both AP and client) is probably is a typo error in the WEP key. Please doublecheck the WEP key entered on both AP and ACU utility.
03-08-2004 09:55 AM
hi again!
Well i have double checked the wep and its ok, on ap and client, i use a 128bit , any one else got that problem i have now ?
03-08-2004 12:49 PM
it seems to work when i change wep to 64bit , but it should work with 128 i guess ?
any one got the same problem ?
03-08-2004 12:52 PM
03-08-2004 12:52 PM
03-08-2004 12:54 PM
03-19-2004 06:38 PM
i was having the exact same problem before i changed my wep keys on both ends. check your wep key.. you can get a wep key generator by searching google for '128 bit wep key generator' put that new key in and BEFORE you apply it to your access point, read and type in the new wep key in your clients. read and type two at a time. mark it off by twos if necessary, but make sure that they are both exactly the same.
