Assigning DHCP IP address by SSID
I want to assign IP addreses by SSID on the 861W. I have two Vlans on the router on two different subnets, and one DHCP pool for each subnet. On the AP I have two SSIDs on each of the Vlans.
However, when I associate with the different SSIDs, I get an ip address from the same DHCP pool, instead of different pools. I want ip from different subnets with different SSIDs.
Any help is greatly appreciated.
Here's the AP config:
version 12.4
no service pad
service password-encryption
hostname ap
enable secret 5 <hash>
no aaa new-model
clock timezone EST -5
clock summer-time EDT recurring
dot11 ssid Public
vlan 1
authentication open
dot11 ssid Voices
vlan 2
authentication open
username Cisco password 7 <hash>
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid Public
ssid Voices
station-role root access-point
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.2
encapsulation dot1Q 2
no ip route-cache
bridge-group 1
interface GigabitEthernet0
description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
no ip address
no ip route-cache
interface GigabitEthernet0.1
no ip route-cache
bridge-group 1
interface GigabitEthernet0.2
no ip route-cache
bridge-group 1
interface BVI1
ip address dhcp client-id GigabitEthernet0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
no activation-character
line vty 0 4
login local
end
1 ACCEPTED SOLUTION
Silver
Re: Assigning DHCP IP address by SSID
To answer your earlier post, you do not need to create BVI2.
I think you should need to trunk your gig0 interface on the router. Try:
interface Wlan-GigabitEthernet0
switch trunk encapsulation dot1q
switch mode trunk
Let me know if that doesn't work.
Jeff
Silver
Enter the following commands:
int dot0.2
bridge-group 2
int g0.2
bridge-group 2
That should work. Cisco APs use bridge-groups to link the radio interface to the wired side. So despite you correctly configuring the VLANs, all traffic is currently getting placed on VLAN 1.
Thanks.
Do I need to also create BVI 2?
Thanks for the suggestion. However, when I implement these commands clients on SSID Voices (Vlan2) cannot connect to the DHCP server on the router.
Here is my config on the router:
Current configuration : 2200 bytes
! Last configuration change at 10:45:20 EDT Mon Apr 27 2009 by Thomas
! NVRAM config last updated at 15:26:52 EDT Sat Apr 25 2009 by Thomas
version 12.4
no service pad
hostname pa-router
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
no ip source-route
no ip dhcp conflict logging
ip dhcp pool 0
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
dns-server 65.19.88.195
ip dhcp pool 1
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
ip cef
username Thomas privilege 15 secret 5
archive
log config
hidekeys
interface FastEthernet0
no cdp enable
interface FastEthernet1
no cdp enable
interface FastEthernet2
switchport access vlan 2
no cdp enable
interface FastEthernet3
no cdp enable
interface FastEthernet4
ip address 65.19.88.211 255.255.255.224
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface wlan-ap0
description Service module interface to manage the embedded AP
ip unnumbered Vlan1
arp timeout 0
description Internal switch interface connecting to the embedded AP
interface Vlan1
ip address 192.168.0.1 255.255.255.0
ip nat inside
interface Vlan2
ip address 192.168.1.1 255.255.255.0 secondary
ip address 207.136.203.109 255.255.255.252
ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 65.19.88.193 permanent
no ip http server
ip nat inside source list NAT interface FastEthernet4 overload
ip access-list standard NAT
permit 192.168.0.0 0.0.0.255
permit 192.168.1.0 0.0.0.255
no cdp run
control-plane
line con 0
no modem enable
line aux 0
line 2
no exec
transport preferred none
transport input all
line vty 0 4
exec-timeout 120 0
privilege level 15
login local
scheduler max-task-time 5000
end
When I turn on ip packet debugging on the AP, I see packets going to the DHCP server on when I associate with Vlan 1, but nothing when I associate on Vlan 2.
Silver
switch mode trunk
Jeff
537
