10-02-2014 03:48 AM - edited 07-05-2021 01:38 AM
Hi all !
I am currently looking at the Cisco 3850 Catalyst+WLC. I saw that they could be stacked, but you can only have 50 APs registered.
What happens if you link 2 3850 using HSRP ? I suppose you'll be able to register up to 100 APs, but when you want to authenticate your 3850s on an CS, will you be able to register only the "virtual IP" of both devices ? I mean, can you authenticate the 2 devices as one device on the ACS ? (I hope I was able to explain my problem !)
Thanks a lot for your help.
Solved! Go to Solution.
10-02-2014 04:09 AM
Interesting question :)
I do not think you can do this
Two 3850 act as two WLCs & have to register them using each of them wireless management IP on ACS.
But this setup will add complications when defining wireless user subsets (as one 3850 will be the STP root & HSRP primary, so both cannot handle same vlan traffic at given time).
So my suggestion is NOT to do HSRP when enable WLC functionality on it. you can still use 100AP even those two switches acting as two different stacks (without HSRP)
Rasika
**** Pls rate all useful responses ****
10-02-2014 04:09 AM
Rasika
10-02-2014 04:27 AM
Thanks for your answer ! It is quite what I expected... And if you stack both 3850, you'll be able to activate only one WLC ?
