Authentication between AP and WLC
Hi all ,
Is there anyway to authenticate the AP before joins the WLC for security purpose?
Vijay.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
MMC
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Here you go
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a00808c7234.shtml
Scott
-Scott
Hi Scott ,
What is the certificate will be there in Ap 3600 ? MIC or SSC?
Vijay
MMC
Scott
-Scott
Thanks  scott for the claification...
Hello ,
As per your query i can suggest you the following solution-
In versions earlier than 5.0 , WLCs sends Mobility Messages with unicast mode, where the copies of Mobility Messages are unicast to all the WLCs in the Mobility Group. But in version 5.0 , Mobility Messages can be sent as Multicast messages wherein only one copy of the Mobility Message is sent to reach all the WLCs in the Mobility Group. Refer to the Messaging among Mobility Groups section of Cisco Wireless LAN Controller Configuration Guide, Release 7.0 for more information
Hope this will help you.
166
