Authentication in Cisco 5508 Controller
There is a Cisco 5508 Controller and my customer want to authenticate the users using a LDAP Server ( AD) , and the guest users must be provisioned by a LDAP user in web portal
is it possible?
Obs. There is no Cisco ISE.
2 ACCEPTED SOLUTIONS
It is possible, see document
It is possible, see document for LDAP authentication on a 4400:
http://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/108008-ldap-web-auth-wlc.html
You can also use the Windows RADIUS server NPS. It is easier and you can find more examples.
Gold
This section explains how to
This section explains how to configure a Lightweight Directory Access Protocol (LDAP) server as a backend database, similar to a RADIUS or local user database. An LDAP backend database allows the controller to query an LDAP server for the credentials (username and password) of a particular user. These credentials are then used to authenticate the user.
Refer the link :http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wlan-security/69340-web-auth-config.html
Congratulations Ravi!Sadly I
Gold
Bronze
Please refer: www.cisco.com/c
Please refer: www.cisco.com/c/en/us/td/docs/wireless/controller/7-2/configuration/guide/cg/cg_user_accts.html#wp1120909
You can choose specific RADIUS or LDAP servers to provide external authentication on the WLANs > Edit (Security > AAA Servers) page. Additionally, you can define the priority in which the servers provide authentication.
Step 7 If you chose External as the web authentication type in Step 6, choose AAA Servers and choose up to three RADIUS and LDAP servers using the drop-down lists.
Note The RADIUS and LDAP external servers must already be configured in order to be selectable options on the WLANs > Edit (Security > AAA Servers) page. You can configure these servers on the RADIUS Authentication Servers page and LDAP Servers page.
80
