Authentication problem with ACS+Windows2003 AD
We are using EAP-PEAP, ACS 4.1, Windows2003SP2 (Active Directory).
The problem is that wlan clients are not authentication with EAP-PEAP.
The logs on ACS display "internal error"
the internal DB on ACS works fine, but not interacting with windos2003 AD.
Highlighted
Hall of Fame Super Silver
Re: Authentication problem with ACS+Windows2003 AD
Make sure the ACS is part of the domian and that ACS has your windows doiman connected and showing in the group mapping.
-Scott
Any luck.....?
I've the same problem.
Tim
167
