Auto anchor mobility WLAN interface
Hello, I'm in doubt if I can associate the mgmt interface to my GUEST WLAN in anchor controller also. I know that must do it on foreign controller. Since my mgmt interface on ANCHOR CONTROLLER are configured in my DMZ if I realy need to configure the GUEST WLAN with a dynamic interface, I will need to create other Vlan and this make no sense.
Hi a.azambuja, Yes - you can
Hi a.azambuja,
Yes - you can associate your guest WLAN to your management interface - however I would not recommend this.
You would be much better off creating a new VLAN that will manage the guest user traffic so that it is segmented away from any managemnt traffic.
Cheers,
Tks,I mapped to that
Tks,
I mapped to that interface (mgmt) and it works fine with controller located totally inside the DMZ.
Tks !
28
