Automatic Radio Interface disabling of WGB
At a scheduled time every day (11 pm), users are automtically disabled in AD, so that nobody can log into the workgroup bridge.
In the morning they will be re-enabled.
But the radio interface is in the morning in the "disable" state and can only be enabled by a manual restart of the Workgroup Bridge or set up the command "no shutdown" at interface by CLI.
Is there somebody who can help me?
Is there any command to block that?
In Log there are following messages:
Log Buffer (64000 bytes):
Interface Dot11Radio1, cannot associate: EAP authenticating
Feb 10 03:58:39.548: %DOT11-4-CANT_ASSOC: Interface Dot11Radio1, cannot associate: EAP authenticating
Feb 10 04:04:17.564: %DOT11-4-CANT_ASSOC: Interface Dot11Radio1, cannot associate: Too many retries
Feb 10 04:08:45.656: %DOT11-4-CANT_ASSOC: Interface Dot11Radio1, cannot associate: EAP authenticating
Feb 10 04:10:00.656: %DOT11-4-CANT_ASSOC: Interface Dot11Radio1, cannot associate: EAP authenticating
Feb 10 04:10:51.660: %DOT11-4-CANT_ASSOC: Interface Dot11Radio1, cannot associate: EAP authenticating
Feb 10 04:21:30.700: %DOT11-4-CANT_ASSOC: Interface Dot11Radio1, cannot associate: EAP authenticating
Feb 10 04:22:54.708: %DOT11-4-CANT_ASSOC: Interface Dot11Radio1, cannot associate: EAP authenticating
Feb 10 04:27:42.760: %DOT11-4-CANT_ASSOC: Interface Dot11Radio1, cannot associate: Too many retries
Feb 10 04:28:17.760: %DOT11-4-CANT_ASSOC: Interface Dot11Radio1, cannot associate: EAP authenticating
Feb 10 04:29:16.772: %DOT11-4-CANT_ASSOC: Interface Dot11Radio1, cannot associate: EAP authenticating
Feb 10 04:30:36.816: %DOT11-4-CANT_ASSOC: Interface Dot11Radio1, cannot associate: EAP authenticating
Feb 10 04:32:48.836: %DOT11-4-CANT_ASSOC: Interface Dot11Radio1, cannot associate: EAP authenticating
Feb 10 04:33:17.836: %DOT11-4-CANT_ASSOC: Interface Dot11Radio1, cannot associate: Authenticate response timeout
Feb 10 04:34:40.836: %DOT11-4-CANT_ASSOC: Interface Dot11Radio1, cannot associate: EAP authenticating
Feb 10 04:35:21.852: %DOT11-4-CANT_ASSOC: Interface Dot11Radio1, cannot associate: EAP authenticating
Feb 10 04:36:03.852: %DOT11-4-CANT_ASSOC: Interface Dot11Radio1, cannot associate: EAP authenticating
Feb 10 04:36:26.852: %DOT11-4-CANT_ASSOC: Interface Dot11Radio1, cannot associate: EAP authenticating
Feb 10 04:36:37.852: %DOT11-4-CANT_ASSOC: Interface Dot11Radio1, cannot associate: EAP authenticating
Feb 10 04:40:15.852: %DOT11-4-CANT_ASSOC: Interface Dot11Radio1, cannot associate: Too many retries
The Configuration of the WGB:
version 15.2
no service pad
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
hostname xxxxxx
logging buffered 64000
logging rate-limit console 9
enable secret 5 $1$IWoP$2TEpULAAQFyh3/5LbygmD1
aaa new-model
aaa authentication xxxxxxx
aaa authorization exec default local
aaa authorization commands 0 default local
aaa authorization commands 2 default local
aaa authorization commands 15 default local
aaa session-id common
clock timezone MEZ 1 0
clock summer-time MESZ recurring last Sun Mar 2:00 last Sun Oct 3:00
no ip routing
no ip domain lookup
ip domain name xxxxxxxx
dot11 syslog
dot11 ssid xxxxxx
authentication open eap eap_methods
authentication network-eap eap_methods
authentication key-management wpa version 2
authentication client username xxxxxxxxx password 7 xxxxxxxx
infrastructure-ssid
power inline negotiation prestandard source
crypto pki trustpoint TP-self-signed-422515618
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-422515618
revocation-check none
rsakeypair TP-self-signed-422515618
crypto pki certificate chain TP-self-signed-422515618
username xxxxxmin privilege 15 password 7 094D6A0410565A3F59
username xxxxxa2 privilege 15 password 7 09654F041C165653
username xxxxxc0 privilege 15 secret 5 $1$fxqT$g5uUlSYwU51aEBrSkNzIG0
username xxxxxd1 privilege 15 secret 5 $1$/gU7$uC3wTjl7MsOkxFDrwC6ru0
username xxxxxr2 privilege 15 secret 5 $1$YcW/$eQrfnuhu/IRwXrQZHfrj..
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
shutdown
encryption mode ciphers aes-ccm tkip
broadcast-key change 100
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
no ip address
no ip route-cache
ssid xxxxxx
antenna gain 0
stbc
station-role workgroup-bridge
l2-filter bridge-group-acl
bridge-group 1
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
bridge-group 1 input-address-list 700
interface BVI1
ip address dhcp client-id GigabitEthernet0
no ip route-cache
no ip http server
ip http authentication aaa login-authentication login
ip http secure-server
ip http help-path
http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
access-list 1 permit xxx.xxx.xxx.xxx
access-list 1 deny any
access-list 700 permit xxxx.xxxx.xxxx xxxx.xxxx.xxxx
access-list 700 deny 0000.0000.0000 ffff.ffff.ffff
snmp-server community xxxxxxxxxxxxxxxxx RO
snmp-server community xxxxxxxxxxxxxxxxxxxxx RW
snmp-server location xxxxxxxx xxxxxxxxx xxxxxxxxx
snmp-server contact xxxxxxxxxxxx
bridge 1 route ip
line con 0
line vty 0 4
access-class 1 in
transport input ssh
line vty 5 15
access-class 1 in
transport input ssh
sntp server xxx.xxx.xxx.xxx
end
Thanks and Best Regards,
Martin
Hall of Fame Super Silver
Re: Automatic Radio Interface disabling of WGB
I don't thing there is anything you can do. This was a problem in the past also that I have seen or even that the WGB itself would need to be rebooted. Maybe have a machine do a constant ping the WGB overnight and see if the WGB stays up.
-Scott
Hi Scott,thanks for the reply
Hi Scott,
thanks for the reply.
Is it possible to block the port through a keepalive or anything else?
280
