Autonomous APs and Roaming
is it possible to configure auonomous APs to allow clients to roam between them?
Thanks, Pat
Everyone's tags (3)
2 ACCEPTED SOLUTIONS
yes, this is totally possible.
if you are using a PSK, then all you need to do is configure the AP exactly the same way, with the exception of the IP address on the BVI interface.
if you are using 802.1x, then you would want to configure WDS for the key caching.
http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_configuration_example09186a00801c951f.shtml#step1
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
This can be done with any Cisco IOS AP.
As for the WDS, yes, the "WDS Master" is what does all the authenticaiton, and holds the keys for the clients in the network.
HTH,
Steve
HTH,
Steve
I'm assuming this can be done with the 35021 APS with the Autonomous software?
After looking at the doc quickly - essentially, one AP does all the forwarding for the authentication?
Thanks, Pat
HTH,
Steve
Thanks a bunch!!
Hall of Fame Super Gold
Just be careful.
3500 running autonomous IOS is not supported by Cisco TAC.
903
