01-21-2009 03:49 PM - edited 07-03-2021 05:02 PM
I am having a problem when I try to configure my AP1131 to a port in a WS-C3560-24PS-S. I've always known that the switchort must be configured as a trunk.
I will try to give a clear explanation of what I've done:
In the AP.
1.- ip address
2.- default gateway
3.- vlans configuration
4.- map SSIDs to vlans
In the switch.
Only configure the port as a trunk
interface FastEthernet0/9
switchport mode trunk
This way I can do everything. Get access to the network, ping, telnet other devices, but not administer nor ping the AP. But if I configure the switchport as an access port:
switchport access vlan 10
switchport mode access
This way I can ping other devices from the AP, ping and telnet the AP from the wired network (my laptop). I can connect to the SSID but not ping nor telnet AP or other devices.
I hope that someone give a clue of what I'm doing wrong or forgetting to configure.
Thanks a lot
01-21-2009 07:57 PM
Have you tried going through the Wireless LAN Controller and Lightweight Access Point Basic Configuration Example (Document ID: 69719)?
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a0080665cdf.shtml
Does this document help?
01-21-2009 08:01 PM
If vlan 10 is your native vlan for the IP address, do you need the following:
switchport trunk native vlan 10
I'm not familiar with your situation, but if switchport access vlan 10 make it work, then you'll probably need to specify which vlan is the native vlan for the trunk (vlan 10) I suppose.
