You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Best option to connect 5 buildings???
1) I have 5 buildings
2) They can not see to each other
3) But they can see a mast in a mountain
4) Distance between buildings and the mountain is 3 km
Question is...
How many BR350 do I have to use?
How many and what type of antennas do I have to use?
I need your help!!!
Thanks a lot...!
  • Getting Started with Wireless
Re: Best option to connect 5 buildings???
The "Best option" is if all building have a line of sight and build a meshed point to point network.
You do not have this option as you have already stated that they do not have a line of sight.
Given this you next best option is a spoke and hub point to multipoint design
Root Bridge on the tower on the mountain with a omni direction antenna or a directional one if all of the buildings fall in the coverage area of the selected antenna
The one bridge per building.
If you expect a High level of traffic then you can start to break this down to smaller radio networks, up to 3
For example
Have root bridge number 1 on the tower using channel 1 and building 1 and 2 associate to this
Have root bridge number 2 also on the tower but use ch 6 and a different ssid have buliding 3 and 4 associate to it
Have root bridge number 3 on the tower using ch 11 and a 3rd ssid and have building 5 associate to it
Then break up your broadcast domain via a router at the tower site and the 3 radio networks in different subnets
For an even higher level of traffic then use a router at each of the 5 buildings so broadcasts on the buildings lan are not sent out the radio network and only the traffic that needs to.
As you can you can scale up your network as needed
Thanks a lot for your answer...
But I have got another question for you...
I am not so sure of what find of antenna should I use.
Consider that there is a distance of 3 km from the mountain to the last building...
help me please...
Thanks!
It all depends on the area you need to cover.
Here is the spec sheets to the antenna avaiable I hope this will help you.
http://www.cisco.com/en/US/products/hw/wireless/ps469/products_data_sheet09186a008008883b.html
You also should use the range calculator to expriement with different antenna combinations and coax etc
http://www.cisco.com/warp/public/102/wlan/faq-hardware-us-calc.html
Another good resource for this is your Cisco reseller or account team who will be able to recommend local system intergration services to help you.
Without LoS a wireless solution might not be the best solution. Why not consider some type of terrestrial circuit (fiber, Ethernet). Maybe run the wireless solution as a backup if you really wanted to implement it.
-- CCNP, CCIP, CCDP, CCNA: Security/Wireless Blog: http://ccie-or-null.net/
301
