Best practices in wireless configuration?
Is there a best practice document that shows 3500 AP with 5508 controllers? The questions I have are below.
1. Do I configure each AP to non overlapping neighbor channels(1,6,11 for 2.4GHz) or leave that to controller to decide? Does controller change the channel of an AP when it sees congestion on a specific frequency?
2. For 5 GHz is it good idea to bond the channels? What frequency to use for neighboring APs? OR again, leave it to controller to shift as needed?
3. For security what's best practices? 802.1x or different?
Sm
Hall of Fame Super Gold
Re: Best practices in wireless configuration?
Let the controller(s) decide.  By default the Dynamic Channel Assignment (DCA) verifies the channel for interferrence every 600 seconds.  Because you have 3500 then make sure you enable Event Driven RRM (Radio Resource Management) on both channels.
The controllers will not change the channel when it sees congestion.  The controller will change the channel if it sees interference on the same channel.  The CleanAir will change the channel when it sees interference from non-AP interference like Bluetooth, Microwave ovens, cordless phones, etc.
Sure.
Leave this option in default.
Sure.
You might also want to check out the WLC config analyzer.
https://supportforums.cisco.com/docs/DOC-1373
726
