Best setup for 802.11r support on 3502i running autonomous
Hello all,
While I received new 3502i yesterday so I upgraded both 3502i from JA to JB4 but I noticed new feature called 802.11r Configuration in the following link: http://www.cisco.com/c/en/us/td/docs/wireless/access_point/ios/release/notes/15-2_2_JB.html#wp337892
I am wondering is there a way to setup best way or recommend. All devices I have is connected to 3502i are 3 laptops, 3 gaming consoles, 5 smartphone and apple, and sometimes 3 to 20 guest with smartphone. 3502i running same SSID and WPA2-PSK AES but different channels on dual band. I would like to test within steamless like at least 50 ms between two 3502i.
By the way, which can I use two setting, over-air or over-ds I don't know what these mean.
1 ACCEPTED SOLUTION
VIP Purple
HiI have not tested or
I have not tested or configured this feature, but as per the document, it seems like you need to have WDS (Wireless Domain Services) to get this working.So one of your 3502i need to configure as WDS.
The following types of roaming are supported over the wireless domain services:
Fast transition over Distributed System (DS)
Fast transition over Air
As long as you use WPA2/PSK, roaming will work without any WDS. So easiest solution would be depoying it without 802.11r & test the roaming time.
Rasika
**** Pls rate all useful responses ****
VIP Purple
Rasika
Hi Rasika,It seem work
Hi Rasika,
It seem work without 11r Configuration. Thanks again!
208
